FS: D16 SOHC Turbo Kit
Old Apr 25, 2005 | 08:41 PM
The Mista Mike's Avatar
Default FS: D16 SOHC Turbo Kit
Here's what I have for sale:
-<U>SOLD!</U>Cast CRX HF manifold - Great Shape $45
-<U>SOLD!</U>HF Mani Adapter plate for Mitsu turbo (14b, T25, 16g) - THICK!!! like 3/4". This thing DEFINITELY won't break. $20
-Mitsubishi 14b turbo - Guy I bought it off of recently had it rebuilt apparently. Very little shaft play. Wastegate actuator is polished and turbo is nice and shiny from me polishing most of the compressor side. There are a couple of small cracks in the exhaust port, but this is normal for Mitsu turbos and it won't hurt a thing! Supposed to be set at 5.5lbs but I never ran it so I cannot guarantee anything. Also has the factory J 2" pipe so you can mount it up to the IC piping. Also has a DSM o2 in it the exhaust elbow. $175
-2.5" IC piping - Some is polished, some isn't. I have a 4' straight section and 2 nice u bends. $70
-Front Mount Intercooler - Ends tanks are semi polished. It's about 28" x 6" x 2.5". Great shape, never used, I bought it new. Inlet is 2", outlet is 2.5". $200
-<U>SOLD!</U>DSM 1g BOV - This thing is pretty sweet. This is supposed to be a VERY loud BOV. It is mounted on a 2" pipe. $45
-<U>SOLD!</U>Autometer Gauges - Mechanical boost gauge and mechanical oil gauge. I have installed them in my car, but they aren't hooked up yet. $90
-96-00 Civic Bezel Dual Gauge Pod - Has two pods to hold the gauges and bolts right around the factory gauges. $30
-<U>SOLD!</U>Custom Downpipe - This mounts up to the factory exhaust elbow from the Mitsu turbo and has a flange for the factory exhaust. Kinda rigged. Needs to be welded. $40
-Missing MAP Link - Only has one of the screws with it, but I do have the unit itself. $45
-Odds and ends - Some random vacuum lines. I also have a TON of old T25 parts. Compressor and Exhaust housings. Wastegate actuator. Exhaust elbow with o2 plug. I have a couple of 2.5" clamps and 2" couplers that might help you out, also. $75
The only thing needed to complete this is some good fuel management, some random fittings like couplers and clamps, 10 ft. of vacuum hose, and some oil lines. Its all small and you could probably snag the rest for under $200 easily. Hit me up on PM or in this thread. Thanks a bunch guys.
Pics:
Other old T25 parts (Compressor Housing, Exhaust Elbow, Wastegate Actuator)
Random Piece of 2" IC piping with Couplers
This would work well as an intake pipe for your filter.
2.5" IC Piping
This stuff is BRAND NEW! Never been put on the car or pulled out the plastic for that matter. You can see my polishing job on the 4' section. It's not the greatest job, but it still looks really good.
(Deodorant does not come with the kit)
14b Turbo
You can see the crack in that last picture. Like I said, its nothing major and it shouldn't hurt a thing.
Intercooler
There you go. If you have any questions, please contact me.
Modified by Mistamike17 at 6:00 PM 4/27/2005
Modified by Mistamike17 at 6:37 PM 4/27/2005
Modified by Mistamike17 at 5:37 PM 5/1/2005
Modified by Mistamike17 at 6:18 PM 5/1/2005
Modified by Mistamike17 at 10:04 PM 5/1/2005
Modified by Mistamike17 at 10:05 PM 5/1/2005
Modified by Mistamike17 at 11:47 AM 5/2/2005
Modified by Mistamike17 at 8:13 PM 5/4/2005
Modified by Mistamike17 at 8:14 PM 5/4/2005
Old Apr 25, 2005 | 09:38 PM
neocrynym's Avatar
Default Re: FS: D16 SOHC Turbo Kit (Mistamike17)
pm'd
Old Apr 26, 2005 | 05:11 AM
Default Re: FS: D16 SOHC Turbo Kit (neocrynym)
replied... morning bump.
Old Apr 26, 2005 | 11:11 AM
Bump
Old Apr 26, 2005 | 01:19 PM
Triple T.
Old Apr 26, 2005 | 04:15 PM
Once again...
Old Apr 26, 2005 | 07:15 PM
Downpipe pending...
Make offers on what you want. If I can sell most of it parted out, then I will.
Old Apr 27, 2005 | 04:40 AM
Bump before class.
Old Apr 27, 2005 | 12:18 PM
And the after class bump.
Old Apr 27, 2005 | 01:56 PM
neocrynym's Avatar
downpipe sold to me
Old Apr 27, 2005 | 01:59 PM
Downpipe shipped bump.
Old Apr 27, 2005 | 08:49 PM
Sleepy time bump
Old Apr 28, 2005 | 04:56 AM
Morning bump.
Old Apr 28, 2005 | 12:08 PM
Afternoon bump.
Old Apr 28, 2005 | 03:50 PM
red_hatchback's Avatar
hey $25 shipped for the adapter plate check you IM
Old Apr 28, 2005 | 06:28 PM
Default Re: FS: D16 SOHC Turbo Kit (red_hatchback)
PM replied. Adapter Plate pending.
Old Apr 28, 2005 | 08:30 PM
sending the money tomorrow
Old Apr 28, 2005 | 10:04 PM
Bump... hittin the sack.
Old Apr 29, 2005 | 04:34 AM
Bump in the morning.
Old Apr 29, 2005 | 12:53 PM
Bump for those Friday night lookers.
Old Apr 29, 2005 | 04:28 PM
T-RO's Avatar
bump cause i sent you a PM
Old Apr 29, 2005 | 09:14 PM
Default Re: (T-RO)
PMS replied. Bumpalicious.
Old Apr 29, 2005 | 09:56 PM
Default Re: (Mistamike17)
hey sending the money tomorrow check your IM
Old Apr 30, 2005 | 09:51 AM
Default Re: (red_hatchback)
PMs replied. Bump again.
Old Apr 30, 2005 | 10:26 AM
highvelcty's Avatar
$30 shipped for the bov, or a little more for the bov still attached to the center section of piping? hit me up preferably on AIM
AIM: phd sews
email: ericmeye@colostate.edu
thanks!
~eric
