using thick oil...... can it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">how thick are you talking??</TD></TR></TABLE>
that is pretty damn thick but no it wont mess them up just make them work little harder, honda motors like thin *** oil, but if you have a prob with motor gion through oil then you can use a thicker weight
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedeghatch »</TD></TR><TR><TD CLASS="quote">i think it was 20w50</TD></TR></TABLE>
The only time I used 20w50 oil was in the summer time in the desert w/ temp of 120+ degrees. My engine ran fine without straining at all. But after the summer heat was over I switched back to 10w30 or 5w30 oil.
so can it mess up your bearing when using about that thick of oil?
using that oil and taking the car up to 8k
motor is ls/vtec
motor is ls/vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no0B16a »</TD></TR><TR><TD CLASS="quote">Since we are on the topic of oil...
Anyone try out that new Quaker state oil, the purple label 10w30 synthetic "high rpm" ****???
Any good?</TD></TR></TABLE>
No, I just stick to mobil 1.
quaker is crap plz dont use. i used to work at a lube shop and found out a lot about oil.
Modified by HXvtec at 6:37 AM 4/27/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXvtec »</TD></TR><TR><TD CLASS="quote">
quaker is crap plz dont use. i used to work at a lube shop and found out everything about oil.</TD></TR></TABLE>
So if you know everything about oil.... Whats the good ****?
i used to work at a lube shop </TD></TR></TABLE>
**** lube?
interesting, what type of tests were they running in teh "lube shop" on quaker state?
This oil is brand new, you said you used to work in "lube shop", have you tested this specific kind?....Any proof?
Just wondering...knowledge is power
**** lube?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fred 150 »</TD></TR><TR><TD CLASS="quote">No. I used valvoline 50 weight race oil for years in an teg it made the valves rattle a little until it warmed up but 20w50 won't hurt.
hmm... you may have solved my problem i just recently changed to mobil 1 10w50 and since than i've had a valve rattle ... maybe i'll give an oil change a try this weekend cause it's been bugging me
Mobil 1 10w30 here i come
</TD></TR></TABLE>hmm... you may have solved my problem i just recently changed to mobil 1 10w50 and since than i've had a valve rattle ... maybe i'll give an oil change a try this weekend cause it's been bugging me
correct me if I'm wrong but I believe Quaker State and Penzoil are parrifin wax based oils.
This means there is some wax in the oil to give it the lubrication it needs.
Ever seen a motor that has used this kind of oil for a long time? The valvetrain and almost everything else for that matter will be covered in gunky crap. IF that were to clog your motor, say bye bye....
I stick to Mobil 1, good stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IC33 »</TD></TR><TR><TD CLASS="quote">mobil 1 10w 30
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jethawk »</TD></TR><TR><TD CLASS="quote">Amsoil
that is if you can find it on a shelf!!</TD></TR></TABLE>
AMSoil is available at Canadian Tires.
I use Motul 8100 5W30 for winter, and 300V 10W40 for summer. But alot of people also use AMSoil and Mobile which I believe are also great oils.
that is if you can find it on a shelf!!</TD></TR></TABLE>AMSoil is available at Canadian Tires.
I gotta hook up for Amsoil.
pm me.
Well not so much a hook up but it helps out our FSAE team.
that is if you can find it on a shelf!!</TD></TR></TABLE>I gotta hook up for Amsoil.
pm me.
