Skunk2 Pro B-Series Series 1+ Camshafts
What is needed to run these cams in a stock gsr motor? do i need to upgrade valvetrain? or would stock valvetrain be fine for a street motor? should i upgrade to CTR pistons? how much more power can cam gears make? also im assuming i should get a skunk2 IM manifold as well. i already have the usual Intake/Exhaust/Header....
any help is appreciated. thanks
Dont run them unless you have valvetrain.
Dont run them on stock gsr cr and expect to see huge gains
Dont run them unless you have the capability to tune.. IE hondata/crome/uberdata or better.
These are called PRO-1's for a reason..
The stage 2 style of skunk cams will idle better with the setup you explained..
You could do a set of jdm itr pistons and a 2 layer head gasket which will give you the proper cr to take advantage of these larger cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone »</TD></TR><TR><TD CLASS="quote">Dont run them unless you have valvetrain.
You could do a set of jdm itr pistons and a 2 layer head gasket which will give you the proper cr to take advantage of these larger cams.</TD></TR></TABLE>
ic, what parts do recommend getting
I recomend what I run usually just because of the simple fact that its proven..
Rocket Motorsports valvetrain
(Or Omni's and skunks NEW stuff)
Crome tunning software because its free and a small fee for the full version that adds the datalogging tools..as well having a usefull and helpfull forum specificly.
Neptune is also cool if you dont need to tune yourself, it's cheaper then most engine management systems and has a large resolution tunning grid..
[QUOTE=asefi944]I have the skunk stage one cams w/skunk valve train in my gsr(w/itr block)
and the car pulls great. [/QUOTE
what kinda times r u running? integra gsr or civic w/ gsr?
and the car pulls great. [/QUOTEwhat kinda times r u running? integra gsr or civic w/ gsr?
Hey TBone...
I am in the process of a full build on my GS-R... Got the Pro 1's, and the OmniPower valve/spring/retainer package, with some SRP 11:1 slugs (works out to ~11:5 with Omni valves...), rods, etc.
Do I need to upgrade the LMA's? I know there are cheaper alternatives to the ITR LMA's that Omni posted (Prelude LMA and a washer (https://honda-tech.com/zerothread?id=566420)), and was wondering if it was a must do... A bunch of folks that "should" know, didn't even know that the ITR ran different LMA's, much less if they need to be upgraded with big cams...
Yay/Nay??? (my guess is YAY (and for ~$65, I'd be a fool not to...), but I would like to hear you opinion)
Adrian
Adrian
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asefi944 »</TD></TR><TR><TD CLASS="quote">integra no times yet but w/ 100 octane it dynoed at 205 whp /// head not ported</TD></TR></TABLE>
that's pretty good. what's your c/r at and how much tq did you put down? that sounds a little high on power for stg1's. gives me hope for my gsr with stg2's at 11.9:1 c/r
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asefi944 »</TD></TR><TR><TD CLASS="quote">I have the skunk stage one cams w/skunk valve train in my gsr(w/itr block)
and the car pulls great. </TD></TR></TABLE>
Were talking PRO-1 cams not stage 1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCsideracing »</TD></TR><TR><TD CLASS="quote">Hey TBone...
Adrian</TD></TR></TABLE>
I run stock itr Lma's in my motor
and the car pulls great. </TD></TR></TABLE>Were talking PRO-1 cams not stage 1.
Sorry to bring this back from the dead, but the degree and duration specs I have seen about the Skunk2 Pro Series 1+ cams have been slightly better than thier regular stage 1's.
What also gets me is that if this is Skunk2's wildest cam, why is it the same price as Stage 2's and cheaper than Stage 3's?
I am just trying to clarify some info.
Do any of you actually own a set?????
i do. they are in my motor, and im busy trying to tune them in between my real job, and my side job...
the cams are pretty dam close to the spraybars on the head.
other than that no real troubles really. but i will have it on a dyno soon....
BTW the stage3's have BUNCHES more duration. i compared them to a set of stage3's before we threw them in, and they are close tot he same lift...
Advertised duration is for the most part meaningless. The duration @ 0.050 on the Pro 1's is about the same as S2S2.
Something to think about? Less advertised duration but near identical duration @ 0.050. Would this suggest a more aggressive ramp?
Also like Tbone said you better have someone who actually knows how to tune instead of a "tweaker". The primary lobe ain't no ***** stock like lobe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket »</TD></TR><TR><TD CLASS="quote">
Also like Tbone said you better have someone who actually knows how to tune instead of a "tweaker". The primary lobe ain't no ***** stock like lobe.</TD></TR></TABLE>
AHAHA, i love it .... i want my car to idle like a monster truck!
hey Rocket, how do the primarys on the pro 1's stack up against the primarys on your m22xx cams? Ive been reading up on the pro 1's and the m22x but havent seen much on the m22xx.... Id love to see them stacked up against eachother
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatchattack »</TD></TR><TR><TD CLASS="quote">AHAHA, i love it .... i want my car to idle like a monster truck!
hey Rocket, how do the primarys on the pro 1's stack up against the primarys on your m22xx cams? Ive been reading up on the pro 1's and the m22x but havent seen much on the m22xx.... Id love to see them stacked up against eachother</TD></TR></TABLE>
Our X primary has more duration and lift.
That's why a chip is provided to make it easier for people to enjoy the cams. Most of the time our customers don't have to go to the tuner.
From: chillin in that city called queen creek, but homes the atl
That's why a chip is provided to make it easier for people to enjoy the cams. Most of the time our customers don't have to go to the tuner.</TD></TR></TABLE>
a rocket can u send me a bin. file of this chip becuase i am having the hardest time getting my car to idle right w/ the pro1 i'm using crome to tune
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket »</TD></TR><TR><TD CLASS="quote">I'll send you a free base map as long as you report back to the members here on how it works (good or bad
).</TD></TR></TABLE>
Now thats SERVICE.. Rocket's writing a basemap for someone using a competetors camshaft
).</TD></TR></TABLE>Now thats SERVICE.. Rocket's writing a basemap for someone using a competetors camshaft
a man i appreciate that very much and i will definitely report back and let everyone know
).</TD></TR></TABLE>a man i appreciate that very much and i will definitely report back and let everyone know
hey 6years later can you report back on the chip Rocket made for you?
i'm in need of a basemap too for the pro1's
