Tips on installing Password:Jdm intake on an EM1?
Just bought a Password:JDM power chamber and was wondering if there was anything i should know about the install. I'm pretty much a honda newb so just let me know if there is anything i should watch out for. My car is a 2000 civic si. Is it pretty much a direct just plug the existing hoses in? Any help would be appreciated. Thanks, and yes i did search.
-Mike
-Mike
pretty much a bolt on affair. just remove the rest of the intake resonators that's under the wheel well. It doesn't get any easier then that.
Make sure it does not rub on your strut bar. I had a j's intake and it rubbed pretty badly on the bar and i didnt even know it was happening. Try to fab up a brackett also as it just sort of hangs there flopping around
I started to install the intake, and just didn't know what to do with the existing harness which connects from the nipple on the back of the valve cover to the nipple on the intake. The intake gives a new rubber tube for this connection so a metal harness is left with no connections. Do i just leave the harness hanging around or what? I would take out the harness, but there are two tubes welded together, so the bottom connection would be severed. help would be appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Carparts-Auction.com »</TD></TR><TR><TD CLASS="quote">i would just call if you run into any problems....</TD></TR></TABLE>
dth0ng69
43
Jan 8, 2010 12:54 PM
kABLiuks
Honda Civic (2001 - 2005)
Feb 21, 2008 11:06 PM
Stock R
Feb 1, 2003 02:56 PM
