JG Edelbrock vs. Blox Which one?
Old Apr 25, 2005 | 06:12 PM
BADGUYNY's Avatar
Default JG Edelbrock vs. Blox Which one?
I am interested in a new manifold I have a GSR....current mods are BC Spec 3+ cams and gears, Portflow springs an retainers, es oval exhaust with 2.25 piping, JDM 4-1 ITR header, akimoto short ram, hondata IM gasket
My question is it worth it to spend the extra money for the JG compared with the blox
Old Apr 25, 2005 | 06:39 PM
G U E C O's Avatar
i think jg is too big. what engine do you have? what compression?
Old Apr 25, 2005 | 07:14 PM
BADGUYNY's Avatar
Default Re: (stock93cx)
I have a GSR with stock compression
Old Apr 25, 2005 | 07:24 PM
moto1320's Avatar
Default Re: (BADGUYNY)
Run the Blox. The JG is too big for that set up.
Old Apr 25, 2005 | 07:37 PM
BADGUYNY's Avatar
Default Re: (moto1320)
ok I was thinking about the the JG with a 64+ TB...so I am guessing its best to get the blox w/ a bigger throttle body
Old Apr 25, 2005 | 07:52 PM
D-tuned's Avatar
it depends on where you want to make power. the blox will help with midrange and the JG is for top end(7K to 10K)
Old Apr 25, 2005 | 09:25 PM
emotionisdead's Avatar
Very Emergency!!
i have also heard that the jg one is a little to big for an all motor setup. let alone a stock comp. ratio setup. i just installed the blox intake on my setup, great fit and the finish is better then stock. compared to the stock itr mani, i will give it a thumbs up.
Old Apr 26, 2005 | 06:16 AM
BADGUYNY's Avatar
Default Re: (EmotionIsDead)
I guess I will be getting the blox then
Old Apr 26, 2005 | 07:46 AM
CompressionFed's Avatar
I've always heard that the JG was bad for a stock compression all-motor car, but we recently put one on a swap we did for a customer. Motor was a stock, JDM GSR with the JG. The car dyno'd at 178whp with no noticeable loss in the midrange. More than likely it was just one of those freak things, but we were surprised with the results.
Old Apr 26, 2005 | 07:57 AM
BADGUYNY's Avatar
Default Re: (CompressionFed)
okay seems good...has anyone else had the same results
Since 1983
Jun 19, 2010 06:06 AM
jizzer671
20
Feb 23, 2006 04:32 PM
rcurry14
Oct 6, 2004 10:42 PM
douglas_be
48
Mar 7, 2004 12:29 PM
red civic standard
10
Nov 21, 2003 09:19 AM
