rod bearing specification for h23
Old Apr 25, 2005 | 05:36 PM
hybridpatient95's Avatar
Default rod bearing specification for h23
a friend of mine has a h23 with 240xxx miles on the motor and he spun a rod bearing.. he wants to know what size bearings to get or specification.. since the motor is alittle old..
Old Apr 26, 2005 | 09:39 AM
high_revs's Avatar
bump...how would i know how to identify what bearing i need, etc....thanx...
Old Apr 26, 2005 | 09:54 AM
Innovation's Avatar
Default Re: (all mOtor h23)
There are codes on the pulley side of the #1 rod journal and on the bottom of the block. You need to match the rod/main journal codes on the crank with the codes stamped on the block to get the correct bearings (identified by color) for your application. Be sure to at least plastiguage (dial bore guages are a better way to measure) to ensure your clearances are with in spec.
Old Apr 26, 2005 | 10:02 AM
high_revs's Avatar
thank you......thats a big help...if they arent within spec....would i need to upsize...how would i know about what size to go?
Old Apr 26, 2005 | 12:32 PM
Innovation's Avatar
That really all depends on how much was turned off the crank? Was it a main or rod bearing?
Old Apr 26, 2005 | 12:37 PM
rod most likely.. its making alot of noise i heard it today i was like dam
Old Apr 26, 2005 | 01:12 PM
high_revs's Avatar
im getting ready to change my oil now...im gonna lok for particles and **** in there....then i will go from there...
i find it hard to believe its bearings beacause it only makes the noise at 2,000-4,000, and every bearing i heard b4 that was shot knocked from idle, and this isnt even a knocking...
Alex EX
Dec 8, 2006 10:56 PM
HickamHatch
Dec 17, 2005 04:10 PM
99blackvti
Oct 27, 2005 12:46 PM
99blackvti
Oct 26, 2005 05:41 AM
db2integra
Sep 20, 2004 08:25 PM
