jdm itr hid
Old Apr 25, 2005 | 05:21 PM
kobi2002's Avatar
Default jdm itr hid
I just got the jdm hid lights a week ago. Now the lights seemed dull to me and even one of them turned a rice blue. Well now it has turned purple and is dim and I know its not the power or ground becuase i hooked it to the batt. My question is , is this how they die and is it that quick for a used one? what are the odds that two start to go bad? i changed the fuse and even went as far as putting in a relay and still nothing. Any thoughts?
Old Apr 25, 2005 | 06:57 PM
ebelp's Avatar
Default Re: jdm itr hid (kobi2002)
I've never heard of HID's doing anything like this, but if I had to guess, I'd say that one of your ballasts is going bad. Try swapping your bulbs and see if the problem follows the bulb or stays with the ballast. Either way, go here for parts:
http://www.suvlights.com
Old Apr 25, 2005 | 07:54 PM
stumpyf4's Avatar
The bulbs might be old... switch the bulbs side to side to ensure it is the bulbs and not the equipment. Dull side should move with the bulb.
Bulbs do colour shift as they get old, going yellow when new to white (after about 100hours) to blue to purple. HIDplanet.com has Phillips 4300k bulbs for $75 a pair. They buy in bulk so that's why they're so cheap. I don't think you'll find a cheaper price. Change both bulbs so you have the same colour lights and keep the old ones for spares.
Old Apr 26, 2005 | 04:28 AM
ebelp's Avatar
Default Re: jdm itr hid (stumpyf4)
Wow, $75 a pair is dirt cheap. It wasn't too long ago when I paid $150 each for those things.
Old Apr 26, 2005 | 06:23 PM
kobi2002's Avatar
Default Re: jdm itr hid (ebelp)
just solved my problem. The lights I got had d2r bulbs which should work but they did not have the notches that mated with the lights. So the ballast plug was not on the bulb flush. It lookes like it arc'd a few times and melted the bulb.
bluenc-87
Sep 15, 2015 03:32 AM
jimmy051702
Lighting
Sep 14, 2011 10:47 AM
817boy
Lighting
Sep 24, 2008 10:15 AM
Ek9ReVciVic
Apr 16, 2008 10:39 PM
DC2Header
Jan 29, 2006 11:06 PM
