SRR LCA question
Old Apr 25, 2005 | 05:08 PM
setupjdmeg2's Avatar
Default SRR LCA question
any one with a eg or del sol with SRR lca's have an issue with the shock mount being a little higher then the stock lca, resulting in a 1/4 - 1/2 rise in ride height after install??? i dont know if there sopose to be this way or mabe i got a bad/wrong pair. i ask because after it raised the rear up, i lowered the rear more and blew the rear shocks.
http://www.cardomain.com/id/jdmeg2 - my car page
any help will is welcomed and appresated
p.s. i cant spell
Old Apr 25, 2005 | 05:10 PM
jlacoy82's Avatar
71.192.16.183
Default Re: SRR LCA question (setupjdmeg2)
Ok, heres some help, remove the SRR LCA's and put OEM ones back on, then your car wont be jacked an extra 1/2" and you wont blow shocks.
Why did you install aftermarket LCA's anyways? They are just bling pieces, aside from saving like .37 lbs on each side.
Old Apr 25, 2005 | 05:40 PM
BoostinEJ1's Avatar
Default Re: SRR LCA question (jlacoy82)
nothing wrong with a little 'bling'
i didn't notice any difference in height when i did mine...
Old Apr 25, 2005 | 05:54 PM
BrianDelSol's Avatar
Default Re: SRR LCA question (JdmEGHatch6)
nOTHING HAPPENED TO MINE BUT i DID INSTALL OMNIPOWERS AT THE SAME TIME SO i GUESS i WOULDN'T KNOW.
Old Apr 25, 2005 | 06:03 PM
stormy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, heres some help, remove the SRR LCA's and put OEM ones back on, then your car wont be jacked an extra 1/2" and you wont blow shocks.
Why did you install aftermarket LCA's anyways? They are just bling pieces, aside from saving like .37 lbs on each side.</TD></TR></TABLE>
Actually aside from them being super bling and 1 pound lighter the SPC versions are actually a bit shorter for lowered cars to reduce negative camber
Old Apr 25, 2005 | 06:10 PM
ZacCarter's Avatar
AAnd the sway bar holes are already drilled.
Old Apr 25, 2005 | 06:55 PM
Cory Matthews's Avatar
Default Re: (ZacCarter)
yours are upside down.
Old Apr 26, 2005 | 12:52 AM
Perpetual Concepts's Avatar
Default Re: (b20zej1)
The SRR LCA's are the exact dimensions of a stock LCA. Lighter, more bling, and just as strong if not stronger than stock. People can say what want about bling parts, but these parts actually provide some use. 2lbs. lighter per side is all I have to say.
Old Apr 26, 2005 | 05:03 AM
pgpunkguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZacCarter &raquo;</TD></TR><TR><TD CLASS="quote">And the sway bar holes are already drilled.</TD></TR></TABLE>
Old Apr 26, 2005 | 05:23 AM
Nova_Dust's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20zej1 &raquo;</TD></TR><TR><TD CLASS="quote">yours are upside down. </TD></TR></TABLE>
I think he installed the right way.
For the author, are you using EK LCA on your Del Sol chassis (which is the same as EG, right?) I thought 5th gen uses round end shocks where the 6th gen uses fork?
jdmsupreme2132
Suspension & Brakes
Nov 2, 2009 11:55 PM
2000turbosi
Suspension & Brakes
Mar 15, 2006 04:11 PM
uNF$@#!
Jul 23, 2005 09:50 PM
Nerv2g
30
Oct 24, 2003 01:09 PM
95excoupe
10
Jan 26, 2002 05:47 PM
