what and where can I buy a tool to adjust my coil-overs
I've heard that using two of these rubber strap wrenches works.
They're fairly cheap...and I use mine to loosen my oil filter.
It's called a spanner wrench. Many companies make them, applications should be rather universal such as the one leadfoot posted.
Use the right tool for the right job.
every time some one postes something like this im baffeled as to why you would need one.
are most of you guys using coilovers like omni's were they say you need pre-load?
It really has nothing to do with preload. Notice how on coilovers the perches have groves? Those are for spanner wrenches. Granted often times you can move them by hand but if your coilover uses locking perches or has an adjustable length body, then you need spanner wrenches to properly tighten/loosen them.
Gant
Suspension & Brakes
Sep 21, 2011 08:18 AM
