Why does it smell like roasting clutch?
Old Apr 25, 2005 | 04:15 PM
d16y8EL's Avatar
Default Why does it smell like roasting clutch?
becuase your burning your clutch. NOPE. i'm a pretty good driver, so i'm not roasting my clutch, not leaving my foot on it as i drive, and/or anything else you can blame on me.
So why the heck does it smell like my clutch is burning whenever i get out of my car. Someone mentioned that it was probably my tranny fluid. didnt make sense to me, but i changed it anyway *was due*, smell is still there. its really annoying, and it gets worse the warmer outside it gets. now the girlies dont like this smell, hell i dont like this smell.
Old Apr 25, 2005 | 04:20 PM
Cypher0117's Avatar
Default Re: Why does it smell like roasting clutch? (d16y8EL)
the same thing happened to my uncles car. After he took out the clutch he noticed a nest of mice. Apparently they cralled up the tailpipe in the winter months and made a nice litte family which is now dead. I don't know if your car was sitting for some period of time, but it wouldn't hurt to take out ur clutch and just have a little look inside there.
Old Apr 25, 2005 | 04:21 PM
d16y8EL's Avatar
no it wasnt sitting at all. have had this prob since last year. just wanna get rid of the smell its driving me nuts.
Old Apr 25, 2005 | 04:24 PM
Cypher0117's Avatar
Default Re: (d16y8EL)
did it just start one day or did it start after some work was done on your car?
Old Apr 25, 2005 | 04:33 PM
Paulnsx's Avatar
wierd. it def wouldnt be the tranny fluid.. that doesnt really have anything to do with the clutch. maybe it could have something to do with your hydraulic system (master/slave cylinder). you could also need to adjust your clutch pedal. it has to do with how your clutch is engaged and disengaged and as far as i can think that only leaves your hydraulic system and clutch pedal. i'm not really sure tho, just throwing ideas out there. good luck man.
Old Apr 25, 2005 | 05:07 PM
TurboEM1's Avatar
Default Re: Why does it smell like roasting clutch? (Paulnsx)
bad cat? does it smell like rotten eggs?
Old Apr 25, 2005 | 05:13 PM
AutoXer's Avatar
Default Re: Why does it smell like roasting clutch? (TurboEM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 &raquo;</TD></TR><TR><TD CLASS="quote">bad cat? does it smell like rotten eggs?</TD></TR></TABLE>
Are your brakes dragging at all? Depending on what pads your using, the 'friction material' burning smell could be very similar to clutch.
Old Apr 25, 2005 | 05:24 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: Why does it smell like roasting clutch? (EX_AutoXer)
the clutch also may not be dissingaging propperly if its not the cat or brakes...
Old Apr 25, 2005 | 07:38 PM
d16y8EL's Avatar
I checked the brakes out when it first started, wasnt that.
its not my cat as i only have a resonator. the clutch not disengaging all the way is what i was thinking, but i dont have the means to check it out, and i dont wanna pay a shop for it
Old Apr 26, 2005 | 06:55 AM
EJ8VTEC's Avatar
Mr. Indecisive
either that or before u know it u wont have any clutch left to engage!
Old Apr 26, 2005 | 07:14 AM
Orangecivic251's Avatar
Old Apr 26, 2005 | 12:59 PM
ironlung78's Avatar
what clutch setup do you have???
Old Apr 26, 2005 | 01:19 PM
sadangryboi's Avatar
did u resurface ur flywheel when u put a new clutch in?
Modified by sadangryboi at 2:53 PM 4/26/2005
Old Apr 26, 2005 | 01:24 PM
AutoXer's Avatar
Default Re: (sadangryboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sadangryboi &raquo;</TD></TR><TR><TD CLASS="quote">did u resurface ur clutch when u put a new one in?</TD></TR></TABLE>
You resurface the flywheel when installing a clutch, not the friction plate.
Old Apr 26, 2005 | 01:53 PM
Default Re: (EX_AutoXer)
doh typo sorry
Old Apr 26, 2005 | 02:12 PM
Turbo E's Avatar
clutch fluid level?
HondaLuv3r4Life
Honda Civic (2006 - 2015)
Jan 24, 2019 08:24 PM
jdmstyleEJ6
12
May 9, 2010 04:13 PM
BiziggumS
Aug 12, 2004 09:54 AM
EcstacyRaver
Aug 8, 2003 07:30 AM
jeebusm3
May 5, 2002 12:20 AM
