Can someone show me how to take this off.
Old Apr 25, 2005 | 03:47 PM
SoOHiGH's Avatar
Default Can someone show me how to take this off.
can someone show me how to take this off. is it a automatic flywheel? its welded onto the plate you see here
Old Apr 25, 2005 | 03:56 PM
hxtasy's Avatar
Default Re: Can someone show me how to take this off. (SoOHiGH)
Isn't it the torque convertor? i never worked on an automatic honda though. did you use a RBG?
Old Apr 25, 2005 | 03:58 PM
SoOHiGH's Avatar
Default Re: Can someone show me how to take this off. (pennhatch)
i have no idea what this is. and whats a RBG?
Old Apr 25, 2005 | 04:31 PM
randbcustoms's Avatar
hey man..ok that is the torque converter... look in between the block and the converter and there will be bolts holding it on.. not enough room for a ratchet gotta use a wrench ..its tight..good luck
Old Apr 25, 2005 | 05:12 PM
SoOHiGH's Avatar
Default Re: Can someone show me how to take this off. (randbcustoms)
ty
Old Apr 25, 2005 | 06:47 PM
93turbo16's Avatar
Yep, those bolts are hard to get to. You have to use a wrench on them. And don't drop the bitch on your foot like me, it is heavy.
Old Apr 25, 2005 | 07:51 PM
CivicB18C1's Avatar
Default Re: (93turbo16)
yea thats def a torgue converter, and whatthye sed. use a wrench
Old Apr 27, 2005 | 03:48 PM
SoOHiGH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">Yep, those bolts are hard to get to. You have to use a wrench on them. And don't drop the bitch on your foot like me, it is heavy.</TD></TR></TABLE>
lol
i got the thing off but now i cant take off the crack pulley nut.
Old Apr 27, 2005 | 05:42 PM
LVB18Civic's Avatar
Use a good 1/2in. impact gun (IR,Snap-ON,Etc) or use a long braker bar.
Old Apr 27, 2005 | 06:15 PM
93turbo16's Avatar
Default Re: Can someone show me how to take this off. (LVB18Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LVB18Civic &raquo;</TD></TR><TR><TD CLASS="quote">Use a good 1/2in. impact gun (IR,Snap-ON,Etc) or use a long braker bar.</TD></TR></TABLE>
Right on
Old Apr 27, 2005 | 06:43 PM
Crazydave's Avatar
Default Re: (SoOHiGH)
make sure your air compessor is pumped up good and high to be able to blast the crank pulley bolt off
Old Apr 27, 2005 | 07:14 PM
ironcheftony's Avatar
well there areabout 10 or so 10mm 12pt botls holding the torque convertor on , onto a flexplate, to get to the bolts, go to the very bottom of the convertor and look at it from the oil pan side and u will see the bolts, if not spin the convertor by the crank pulley or convertor it self, to get to all the bolts, be careful on the last 1 bkuz that thing is pretty heavy and u dont wnat it to smash ur foot
Old Apr 27, 2005 | 07:29 PM
SoOHiGH's Avatar
Default Re: (ironcheftony)
i used a braker bar with a 2 ft pole and got that bitch off.
killingtwobirds
Sep 11, 2008 11:13 AM
msinsky14
12
Feb 23, 2007 09:41 AM
BlueShadow
11
Jul 30, 2004 09:20 PM
rubens
Jun 9, 2003 12:40 PM
