Help with civic EG6
Hi all im thinking of doing a bit of tidying up on my car and need a little help from you guys. I live in the UK and there are no Haynes or Helms manuals available to me.
What im wondering is how you take the sunroof out (completely remove from car) it is an electric roof.
Also, the rear side windows, and windscreen. Are these easy to remove yourself and then to put back on. Or is a pr0 required?
Basically im starting a bit of a project on my car in the summer. To respray my car spoon yellow.
Any help will be great
Cheers Andy
Cheers Andy
for the sunroof,remove the headliner,and it will be obvious as there are visible bolts that hold the comoplete assembly on.also,you can remove just the glass panel by opening the sunroof and looking at the bottom edges from inside the car-you will see the bolts that hold the glass to the sliding assembly.
the windows must be cut out-they're held in with urethane.it requires special tools and a little bit of skill,so i;d suggest leaving it to a pro.
Chris
Chris
travis
Apr 11, 2002 09:22 PM
