How do body shops fill in/ cover side molding holes?
Old Apr 25, 2005 | 12:14 PM
CALM_AS_A_BOMB
Guest
Posts: n/a
Default How do body shops fill in/ cover side molding holes?
I was planning on doing this myself if it does'nt require to much expertise. For you fellow H-T people that have shaved side moldings, do you know how the body shop filled the holes with?
Old Apr 25, 2005 | 01:24 PM
jdmjeff's Avatar
Default Re: How do body shops fill in/ cover side molding holes? (D4rk5y3D)
i would go get some fiberglass to fill in the back of the holes and let that dry then sand the front of the holes down to the metal then use bondo on the holes. If you DONT use fiberglass on the holes and you slam your door your bondo could POP out! i would try this. also i would cut a piece of wood the shape of the flat part of your molding... this would make it a lot easier on your hands. hope this helps
Old Apr 25, 2005 | 01:30 PM
Grip's Avatar
Default Re: How do body shops fill in/ cover side molding holes? (jdmjeff)
fill them with weld and grind the weld down..then use a skim coat of body filler to fill any holes or imperfections..the factory uses diffrent door skins..bodyshops would either weld them shut or fill them with fiber/glass bondo...but that method dosent last forever
Old Apr 25, 2005 | 01:35 PM
jdmjeff's Avatar
Default Re: How do body shops fill in/ cover side molding holes? (Grip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grip &raquo;</TD></TR><TR><TD CLASS="quote">fill them with weld and grind the weld down..then use a skim coat of body filler to fill any holes or imperfections..the factory uses diffrent door skins..bodyshops would either weld them shut or fill them with fiber/glass bondo...but that method dosent last forever </TD></TR></TABLE>
yeah true but if he doesnt have a weld, like me, then the fiberglass would do just fine!
Old Apr 25, 2005 | 01:37 PM
AnToNy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjeff &raquo;</TD></TR><TR><TD CLASS="quote">
True, if he can't weld it. I know most body shops weld in the hole and use a little body filler then sand.
duh702dc2
Paint and Body
May 10, 2014 11:43 AM
Hunters teg12
Paint and Body
Aug 16, 2013 05:42 PM
godzhand
Jan 2, 2007 07:29 PM
Audipwr1
May 8, 2003 08:27 PM
FBP Si 2000
Dec 28, 2002 10:53 AM
