Torque spec for crank pulley
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious »</TD></TR><TR><TD CLASS="quote">i think your actually supose to torque it to 150 first.. and then loosen it to 130.</TD></TR></TABLE>
Pretty sure that only applies if you're using a new bolt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stoich »</TD></TR><TR><TD CLASS="quote">Wierd thing i noticed the N1 pulley has splines in the inside where it mounts to the crank yet the crank is smooth am i missing something?</TD></TR></TABLE>
As long as the woodruff key is there you are fine. The spiles on the pulley help with removal, later on down the line.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pcguy760 »</TD></TR><TR><TD CLASS="quote">I dont understand how come we require like 500lb of torque to remove that crank bolt but only 130lb to put it in? That's wierd...</TD></TR></TABLE>
Are you for real? I guess it is the same reason that you torque a brake caliper mount bolt to 28 ft-lb and requires 80 ft-lbs or so to get it off.
Yeah I don't really understand that. I mean only 130Lbs to put it in and then I hear of guys only being able to get it out with huge impact guns and stuff.
Yelling at it might work eh? lol.
