Funny starting issues... searched but couldn't find an answer. Suggestions?
Old Apr 25, 2005 | 10:27 AM
EJ1 wilcox's Avatar
Default Funny starting issues... searched but couldn't find an answer. Suggestions?
This started happening probably about 6 months ago...
Many times when I go to start my car here's what it does:
I turn the key - nothing happens for about 1-2 seconds and then the starter starts cranking... it then takes about 5 cranks to actually get started.
When it's cold it cranks over on the first kick but when it's warm it takes at least 5+ cranks to get started...
I'm thinking that my starter is starting to go out or something. It really shouldn't take 5 cranks for my car to start. Is there a way I can test my starter to see if it is the problem or not?
Any other suggestions as to what the problem might be? I think it's really weird that when I turn the key nothing happens for a few seconds and then the starter randomly starts cranking... what could the problem be?
Old Apr 25, 2005 | 11:02 AM
DBLAZE's Avatar
Default Re: Funny starting issues... searched but couldn't find an answer. Suggestions? (EJ1 wilcox)
Sounds like starter or ignition coil (I could be wrong bout the ignition coil...bump for more suggestions)
Old Apr 25, 2005 | 12:02 PM
MonkeyBoy668's Avatar
Default Re: Funny starting issues... searched but couldn't find an answer. Suggestions? (DBLAZE)
Sounds to me like the starter solenoid is dying. That it pauses after turning the key should mean that's the failure.
Can you replace solenoids seperate from the starters on Hondas though. That I don't know. The old big block V8s I grew up with could be, but that means nuttin'...
Old Apr 25, 2005 | 02:25 PM
EJ1 wilcox's Avatar
Default Re: Funny starting issues... searched but couldn't find an answer. Suggestions? (MonkeyBoy668)
Is there any way I can test my starter to see if it is the problem?
professorman
Mar 18, 2013 10:44 AM
battleREADYb20
Apr 30, 2009 02:36 AM
civicbro
Feb 19, 2004 02:47 AM
crx1856
Aug 20, 2003 10:24 PM
