Si exhaust question
Old Apr 25, 2005 | 10:21 AM
hialeahzbg's Avatar
Default Si exhaust question
wood a 00 si exhaust bolt rite up 2 an ls vtec on a 00 coupe?
Old Apr 25, 2005 | 10:24 AM
hatch34's Avatar
Default Re: Si exhaust question (hialeahzbg)
it should if you still have stock exhaust with the flange
Old Apr 25, 2005 | 10:27 AM
hialeahzbg's Avatar
cuz i tried puttin a 00 type r exhaust and it woodnt bolt up?
Old Apr 25, 2005 | 10:29 AM
hatch34's Avatar
Default Re: (hialeahzbg)
cause a type r is 2.5
Old Apr 25, 2005 | 10:33 AM
hatch34's Avatar
Default Re: (hatch34)
and the bolt pattern on teh flange is diff
Old Apr 25, 2005 | 10:34 AM
hialeahzbg's Avatar
the tranny is a b16 tranny so it should bolt rite up 2 the si tranny rite?
Old Apr 25, 2005 | 10:36 AM
chads's Avatar
buy my 00 civic si header and cat back
only 40k miles
Old Apr 25, 2005 | 10:37 AM
hialeahzbg's Avatar
it has si headers but will it bolt rite up?
Old Apr 25, 2005 | 11:13 AM
Sijray21's Avatar
i want to help, but i'm soo confused by this thread...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">it has si headers but will it bolt rite up?
an lsvtec setup cannot have an si header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">the tranny is a b16 tranny so it should bolt rite up 2 the si tranny rite?
...not sure the point of this question, unless it's a whole other question all together
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">wood a 00 si exhaust bolt rite up 2 an ls vtec on a 00 coupe?
what are you asking? what kind of header do you have?
if you have an ls vtec set up you can't run a header that was on the civic Si, the block is longer and it will not clear.
If you are doing a swap you will more than likely have to reweld the flanges on the exhaust or cat to allow for fitment. More than likely you will need to have a b18 header of some sort and do a weld job on the flanges of the exhaust to get it to fit on a '00 civic coupe. The Si's exhaust is not different than that of a regular '00 exhaust....except you get the bling-bling chrome exhaust tip cover....
Old Apr 25, 2005 | 11:18 AM
hialeahzbg's Avatar
my bad i wrote the wrong thing i have ls vtec but wood si piping( exhaust) fit?
eguti66
Dec 1, 2006 11:15 AM
Mikes2000civicsi
Oct 25, 2006 12:23 PM
EF9 JAMS!!!
Aug 23, 2005 04:45 AM
gulf imports
May 30, 2004 03:06 AM
