injectors?
Old Apr 25, 2005 | 09:25 AM
95strfytr's Avatar
Default injectors?
How do you know when you need new injectors? I swapped a d16y7 in place of my old d15b8. The old injectors had about 150000 on them. I swapped in a AEM rail, FPR, and a BBK fuel pump, too. It has a hard time starting, idles rough and fluctuates, poor acceleration, and no matter what the FPR is set at, the plugs(Denso iridium) are still a little lean. Need help? I estimate that I should have about 160 hp with these and the other bolt-ons.
Old Apr 25, 2005 | 12:45 PM
DBLAZE's Avatar
Default Re: injectors? (95strfytr)
If you replaced all of those other fuel components, then you should definitely change the injectors too....It could be a bunch of things though like tune-ups, plugs, cap-n-rotor, etc...
Old Apr 25, 2005 | 01:04 PM
ARIZONA's Avatar
Default Re: injectors? (DBLAZE)
Try replacing with newer injectors.. I estimate your HP at 117 with those mods.
also, your iacv might need to be screwed in and if you are properly setting your fuel pressure, you need to keep it near stock wide open throttle values. I am assuming you probably have intake/header/exhaust.
Old Apr 25, 2005 | 01:19 PM
Harassing Herbs's Avatar
Default Re: injectors? (ARIZONA)
make sure your fuel pressure is at stock settings. check your plugs. you may be pushing too much fuel through your injectors now.
Old Apr 27, 2005 | 06:43 AM
95strfytr's Avatar
Default Re: injectors? (Harassing Herbs)
Fixed the problem. I needed to install the bigger gold orifice that came with the AEM FPR. I was getting to much back pressure in the fuel system whenever I installed the fuel pump. The other problem that I had was the ecu. It's fried. I put another one in and it started up and runs great. Feels like I got a crap load back, especially torque. I also had to replace the injectors. The surge was apparently tooo much for those old injectors and they just couldn't take it anymore. The pressure was so much that to strainers in the top of the injectors tore and collapsed in on all four of them. Thanks guys.
Old Apr 27, 2005 | 10:32 AM
D15B_Ej6's Avatar
you wish you had 160hp with a y7...my old y7 had pretty much every bolt on and i doubt i broke 100 hp.
andrewd_89
Engine Management and Tuning
Dec 4, 2009 02:43 PM
rdeezy78
Nov 24, 2008 05:15 PM
inkong
Aug 17, 2007 06:05 AM
2000d16y7
Jul 16, 2007 01:49 PM
JDM turbo DC
Mar 24, 2006 05:44 PM
