diff between p13 jdm ecu and p13 usdm ecu
Old Apr 25, 2005 | 01:34 AM
mprelude's Avatar
Default diff between p13 jdm ecu and p13 usdm ecu
wut is the diff between p13 jdm ecu and p13 usdm ecu
Old Apr 25, 2005 | 03:11 AM
herovueboi's Avatar
JDM P13s have a speed governor lower compared to the USDM P13 Ecu.
Old Apr 25, 2005 | 06:18 AM
Monkey Fing a Coconut's Avatar
Default Re: (herovueboi)
also, supposedly(sp?) the jdm runs a little richer and has different maps to account for the .6 increased comp ratio
Old Apr 25, 2005 | 08:38 PM
mprelude's Avatar
Default Re: (twistedbydezign)
it wouldnt hurt if i use it on a H22A4 and is the rev limit diff
Old Apr 26, 2005 | 04:06 AM
Default Re: (mprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mprelude &raquo;</TD></TR><TR><TD CLASS="quote">it wouldnt hurt if i use it on a H22A4 and is the rev limit diff</TD></TR></TABLE>
i believe h22a4 = 5 gen = obd II, p13's are obd I so you would have to get a conversion harness, also i believe you would need the obd I dizzy and injectors, but someone else will have to verify that, and the rev limits/fuel cutoff are the same = 7600rpms
Old Apr 26, 2005 | 05:07 AM
crxhybrid85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by herovueboi &raquo;</TD></TR><TR><TD CLASS="quote">JDM P13s have a speed governor lower compared to the USDM P13 Ecu.</TD></TR></TABLE>
I can't say anything about the JDM ECU cause I never topped my car out running it, but I can say with certainty that my 96 USDM P13 has no speed limiter whatsoever I took my **** up almost to the fuel cut in 5th gear, I'm not going to trust the stock speedo too much but that **** was about an 3/4 of an inch past the 150 mark.
pkolaboy
Apr 15, 2008 08:31 PM
kobeRy_si
May 14, 2007 11:17 AM
Lauj87
Oct 16, 2005 10:27 AM
Lee_Delso
Dec 11, 2004 10:47 AM
TomTom
Aug 26, 2002 07:10 PM
