B16 Build
Old Apr 24, 2005 | 09:37 PM
L-TownGSR's Avatar
Default B16 Build
Hey everyone, im goin all motor with my project cuz everyone uses a turbo and i look at it as cheap power.
anyways i have
P72 GSR head
ITR valves and valve springs
ITR cams
CTR standard bore pistons
B16A block
Skunk 2 intake manifold
CTR crank pulley
I plan on getting a 2 ply head gasket, and hondata intake manifold gasket, and a toda timing belt
how much power should i be making out of this setup?
I still need a header, ecu, cam gears, intake, ect. what kind of parts should i get for these?
Thanks for your help
Old Apr 25, 2005 | 12:33 AM
jdm123's Avatar
Default Re: B16 Build (L-TownGSR)
why not just use the b16 head?
Old Apr 25, 2005 | 02:03 AM
No_Fear's Avatar
Default Re: B16 Build (jdm123)
maybe to get higher comp,a similar setup,with b16a cams ,put with 5zigen manifold and AEM cai intake made 164whp.
Old Apr 25, 2005 | 10:21 AM
L-TownGSR's Avatar
Im using the P72 head because i bought the block and head seperate, and the P72 head has a smaller combustion chambr volume so it will raise the compression about .3 points.
thanks for your help everyone
Old Apr 25, 2005 | 10:50 AM
Grip's Avatar
your probally looking at 145-155 hp..i have a similar setup and made less because i have stock cams..jun 2's, diy itb's, and an-r compact header w/merge collector coming soon
sorry..i didnt relaize you had ctr pistons as well...i dont have those..so i dont know what you can guesstimate..im using stock b16 p30 pistons
Old Apr 26, 2005 | 09:34 AM
Colt Seavers's Avatar
B16 block with CTR pistons and GSR head with square cambers be careful
Old Apr 26, 2005 | 02:15 PM
L-TownGSR's Avatar
Default Re: B16 Build (Colt Seavers)
what do you mean by be careful? jw<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Colt Seavers &raquo;</TD></TR><TR><TD CLASS="quote">B16 block with CTR pistons and GSR head with square cambers be careful </TD></TR></TABLE>
Old Apr 27, 2005 | 12:14 PM
The reason I said that is because the CTR pistons stick out of the top of the block because the CTR block is different, and if you are going to use a GSR head with square chambers the piston is going to smash into the head and become your worse nightmare. So you might want to change some thing before you put everything together. By the way CTR's are super heavy, try some JE's I'd recomend them.
Old Apr 27, 2005 | 06:28 PM
L-TownGSR's Avatar
do you know where i could get some JE's or how i couldstop my piston from smashing the hell out of my head like you say
Old Apr 27, 2005 | 07:14 PM
Kendall's Avatar
I don't think 170 whp is out of the question if you have good engine management. But my biggest question is why would you want to go with a 2 layer headgasket. You're already undercammed with the setup as is. I'm going to recommend bigger cams before adding more compression.
Old Apr 27, 2005 | 09:10 PM
L-TownGSR's Avatar
Default Re: (Kendall)
what kind of cams would you reccomend?
Old Apr 27, 2005 | 10:46 PM
UncleD's Avatar
Default Re: (L-TownGSR)
S2S1/Blox type A...perfect for what you want to do.......
Old Apr 28, 2005 | 08:57 AM
L-TownGSR's Avatar
Default Re: (clean rice)
alrite, thanks, do you know how much they could get me at the wheel if i go with htose cams? thanks for your help everyone
Old Apr 28, 2005 | 09:35 AM
If you really want to use those pistons try to get a LS or GSR block they will fit in those because the b16b block is the same deck height. I'd try to get some jun3's those cams are the **** don't get mislead by what these other people tell. Hit me up if you have any other questions
Old May 13, 2005 | 07:01 PM
Sketch_hs's Avatar
Default Re: B16 Build (Grip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grip &raquo;</TD></TR><TR><TD CLASS="quote">your probally looking at 145-155 hp..i have a similar setup and made less because i have stock cams..jun 2's, diy itb's, and an-r compact header w/merge collector coming soon
sorry..i didnt relaize you had ctr pistons as well...i dont have those..so i dont know what you can guesstimate..im using stock b16 p30 pistons </TD></TR></TABLE>
i made 158whp n/a I/H/E b16a2
Old May 13, 2005 | 07:18 PM
radteg's Avatar
u can get somewhere around 180 with some good tuning....but i don't think u will have a problem with the pistons and the head that u have..i have b16 block and ctr pistons and when putting them in it was perfect i don't see how it would smash into the head.....it didn't stick out at all.stay with what u have and do lil block upgrades while ur at it...save u time and money later on
Old May 13, 2005 | 07:54 PM
PyroProblem's Avatar
I would take the head off, get a nice port job, and some bigger cams w/ valvetrain...
All the power is made through the head, thats where you should put your $...
RACING INTEGRATION
10
Dec 10, 2007 12:56 AM
L-TownGSR
Apr 20, 2005 10:07 PM
salbaje
Nov 19, 2002 06:41 PM
tooqwik1
Aug 3, 2002 06:05 PM
ahcjar103
Oct 31, 2001 01:50 PM
