FS: RSX Turbo Kit, some audio stuff, guages, miscellaneous stuff..
Full turbo kit includes:
-Garrett t3/t4 60-1
-Tial 38mm wategate w/blue top
-Full 3" DP WITH Full 3" Turbo back exhaust with APEXi N1 turbo muffler
-Greddy Turbo Timer
-24x12x3 intercooler with brackets
-Turbo XS Dual Stage Boost controller
-Greddy Type-s BOV
-OBX Manifold, Heat Wrapped
-Heat wrapped dump tube
-Turbonetics hoses with the GOOD clamps
-550cc injectors w/clips
-Guardian E.I. with wiring diagram
-Oil Feed and Return Lines
-All necessary clamps hoses, ect. that will be needed to make this work
2 Things that you will need with this custom kit, is a CAI because i used my old one to make it goto the TB, and also guages, or you can buy mine below as well...
$2500+Shipping
Defi BF Series Guages:
Boost, EGT, and Oil Press.
Controll unit
EGT and Oil Press come with BRAND NEW sensors!
$600+Shipping
Pioneer AVIC N1 Pop out screen:
-US and Canada dual DVD map discs with 12 million POI (including Hawaii and Alaska)
-RISC CPU for navigation and vehicle dynamics display functions
-exclusive 32-bit positioning CPU
-64MB SDRAM
-flash memory
-graphic processor
-3D hybrid sensor
-voice control interface (with optional mic CD-VC1)
-GPS receiver and antenna
-ultra-slim built-in DVD/CD/MP3 player
-compatible with DVD-video/DVD-R/RW/CD/CD-R/RW/MP3
-96/48/44.1 f.s. 24-bit 2ch DA converter
-CD-text with ID3 tag
-6.5" widescreen TFT active matrix LCD color display
-touch panel control with AG (anti-glare) coated screen
-fully motorized mechanism with display angle adjustment
-automatic display position
-intelligent dimmer control
-picture adjustment (brightness contrast color hue dimmer settings)
-independent rear-view camera input and split screen IC
-10 character sub display with scroll (XM only)
-new enhanced color GUI & animated background images
-background images downloadable from CD-R
-direct source selection by touch
-multi-channel processor ready (optional OEL controller & processor)
-MOSFET50 (50 watts x 4 channel high power)
-3 pair preout
-3-band parametric EQ
-direct subwoofer driver
-supertuner IIID (AM/FM)
-IP-Bus system control (XM ready MCD control dual DVD control aux input 2 external unit control)
-AV bus input
-composite A/V input for VCP or game
-composite A/V output for tri-zone function
-background video capability
-detachable face security
$1000+Shipping
nitrous kit for sale that was installed on his rsx that is hidden... That is, the solenoids and the lines and everything are hidden, he put this on his car beat on camaros popped his hood and they saw nothing.. what i did was took a 2nd fuse box off a saab and put the nitrous solenoids in it... anyways check out the pics to see in detail:
Nitrous Kit includes:
-NOS Nitrous and Fuel Solenoids
-SAAB Fuse Box gutted out
-All Lines necessary
-AEM Fuel Rail (this makes the install SOOO MUCH easier)
-NEX Bottle Heater
-Switch panel for your vent in your car to turn everything on/off with foam cover
-Nitrous Purge with all accesories
-NOS 10lb Bottle
-Bottle Brackets
-All wiring and relays
Price: $475+Shipping OBO
Pictures of nitrous kit can be found HERE
Absolutely NO PARTING PM FrcFed94GSR with interests..
Nitrous Kit
Turbo Kit
Pioneer Avic N1
Unit Closed and on radio
Unit open and on Radio
Unit on GPS screen
Playing Matrix DVD (this unit will play dvds while driving if hooked up
correct :thumbsup: )
Source Menu (this thing has way too many options)
GPS Antenna on my dash
A/V Hookups for PS2/XBox/Camera whateva :cool:
The N1 Brain/Satelite Commander
This is a pic with the flash on so you can see the care that i have
given this beautiful unit, NO SCRATCHES! GUARNTEED SATISFACTION!! as you
can see there are only finger marks on the screen where i have touched,
thats it, those can be wiped off!
System
Khoi
Modified by Sohc Driver at 8:38 AM 4/30/2005
-Garrett t3/t4 60-1
-Greddy Turbo Timer
-Greddy Type-s BOV
$2500+Shipping
Controll unit
$600+Shipping
-64MB SDRAM
-flash memory
-graphic processor
-3D hybrid sensor
-3 pair preout
-AV bus input
$1000+Shipping
-NEX Bottle Heater
-NOS 10lb Bottle
-Bottle Brackets
Nitrous Kit
Turbo Kit
Pioneer Avic N1
Unit on GPS screen
System
,Khoi
$ISELLTOU4LESS$
Nov 3, 2010 03:30 PM
$ISELLTOU4LESS$
Texas -OK -LA (Sales)
Nov 6, 2006 06:13 AM
$ISELLTOU4LESS$
Southeast (Sales)
Nov 4, 2006 07:34 PM
$ISELLTOU4LESS$
Nov 4, 2006 04:36 AM
too poor cause of the turbo setup i want to run....oh well, good luck. free bump!
