tranny changing a/f ratio
Old Apr 24, 2005 | 07:06 PM
DeadVet's Avatar
Default tranny changing a/f ratio
I was running a built a6/z6 motor with a dx tranny and 12psi. Yesterday i switched to an si tranny and installed some motor mounts. I went to drive it today and noticed that it kind of hesitated in 3rd gear at WOT like it was pig rich. I havent had a chance to hook the wide band up and check the a/f. When switching to a tranny with a shorter gear ratio will it change the a/f ratio and if so will it make it richer or leaner?
Old Apr 24, 2005 | 08:27 PM
adseguy's Avatar
Default Re: tranny changing a/f ratio (1TurboHatch)
http://uberdata.pgmfi.org/forum/
If you don't like reading and learning...don't use Uberdata.
This is like a DIY project so **** will go wrong and you will stumble along the way, but once you get it workin it's <FONT COLOR="yellow">****** AMAZING</FONT>.
PRLSV
May 2, 2012 05:43 PM
sins
Aug 10, 2010 02:34 PM
boostinnc
Transmission & Drivetrain
Jan 2, 2010 01:37 PM
DeadVet
Apr 25, 2005 04:48 PM
