ZC timing ?
Old Jan 31, 2002 | 03:38 PM
Hondasaurs's Avatar
Default ZC timing ?
I just repaced the timing belt on my DOHC ZC and I'm having trouble getting my timing set correctly. Right now the car runs, but when I press the gas the rpm's slowly increase then the car stalls. I'm no expert on timing thats why I'm asking for some advice. I believe I need to advance the timing.Any advice on how to do this?
Old Jan 31, 2002 | 03:44 PM
Aphrodavid's Avatar
Default Re: ZC timing ? (ZC_CRX)
yes, the timing is very retarded. you can fix it by rotating the distributor. or if that doesnt fix it, you could be off a whole tooth.
Old Jan 31, 2002 | 03:51 PM
Hondasaurs's Avatar
I just did a search and found this link: http://www.c-speedracing.com/howto/timing/timing.html
Should the procedure be the same on the ZC?
Old Jan 31, 2002 | 03:54 PM
Aphrodavid's Avatar
yes
Old Feb 1, 2002 | 12:34 PM
therealciviczc's Avatar
Default Re: ZC timing ? (DX-R)
I'll bet you're off by a tooth. Your timing shouldn't be so far off from changing the belt that the car stalls. It really shouldn't be off at all.
Remember that the ZC gears should point in toward each other when you're done. The up arrow on the exhaust cam should be like at like 12:01pm and your intake is at 11:59pm. (not quite that far, but you get the point). This is all when the TDC mark is up (not the three timing marks, but the single TDC mark).
Ex-Eg-Driver
Jan 21, 2008 06:56 PM
luckeydog14
Feb 14, 2005 03:48 PM
vmm
Aug 28, 2004 07:00 PM
vmm
Aug 17, 2004 06:26 PM
2dregcivic757
Apr 21, 2003 04:54 PM
