car will not start....need help
Old Apr 24, 2005 | 01:02 PM
jdm Ef-9's Avatar
Default car will not start....need help
my ef-9 will not start......heres the run down, driving down the highway at 65 mph. i was not beating on it but the car shut down. when it happened, it made a loud poping noise in the cat... im getting spark at my rotor, plugs are new. timing belt is fine, im getting fuel and intake is getting air. now ive been driving the car for 2 weeks after it sitting for 6 months. a friend said an animal could have made a nest in my exaust.....dont know if thats true. but could be a solution. meaning no back pressure......any answers. please post back
thanks
matt
Old Apr 24, 2005 | 01:09 PM
Erik_Pb_Foot's Avatar
New User
Default Re: car will not start....need help (jdm Ef-9)
an animal "making a nest in your exhaust" would get blown out when the car cranked... and it would crank if that was it's only issue. what's back pressure? who cares.... your friend knows nothing.
how do you know it made a popping noise int he cat? how do you know it wasn't out your muffler? or a backfire through your intake? never heard a cat make a popping noise.
your timing belt is "fine" but is the engine in time? check your timing... maybe it skipped a tooth or two... or three....
do a compression test... see if you bent a valve, busted a rod, etc.....
Old Apr 24, 2005 | 01:14 PM
jdm Ef-9's Avatar
Default Re: car will not start....need help (Erik_Pb_Foot)
timing may have gone off.......also, done a compression test.....im fine on that.....wheni crank it eveything checks out but ill try that....but could the timing go off even when driving.?
Old Apr 24, 2005 | 01:22 PM
New User
timing belts get old and skip teeth when something goes a little wrong, a lot wrong, or age catches up with them... not to mention if the tensioner pulley has a quirk in it.....
that woudl be where i would start b/c if you are getting stark and gas then the only reason it shouldn't start (aside from having low/no compression) would be the timing.... as far as i know of anyway...
Old Apr 24, 2005 | 01:25 PM
jdm Ef-9's Avatar
ok thanks.....ill go to the garage and work on that problem.....thanks dude
Old Apr 24, 2005 | 01:49 PM
New User
good luck.
hopefully it's something this simple.
the_lude_01
Mar 24, 2009 03:46 PM
beauduvall
Feb 10, 2004 09:05 AM
Senbonzakura
Jun 2, 2003 03:27 PM
Diegolude
Apr 24, 2003 08:24 PM
tC_Dragon
May 6, 2002 07:53 PM
