MSD rev limiter not working? WTF!
Its a very simple installation and i have gone over my wiring several times. Blk/org to coil wht/red to dist. power and ground. I tried it with a 3 k pill and it doesn't hold. I then put in a 7k pill and still nothing. I thought the box was bad so i grabbed another one from i car i was working on that i just installed and still nothing. Any suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si »</TD></TR><TR><TD CLASS="quote">sounds to me like you forgot to cut a couple wires so its set for 4 cylinder</TD></TR></TABLE>the only other wires are the purple and green which are not used
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si »</TD></TR><TR><TD CLASS="quote">there is a black cap with a screw in the middle on the side of the box if you unscrew it you will see two wires under that cap</TD></TR></TABLE>there is a red and blue wire under the cap. it doesn't say anything in the install instructions about them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si »</TD></TR><TR><TD CLASS="quote">cut both of them....and every system ive installed said to in the directions</TD></TR></TABLE>i'm retarded! thanks bro. i guess i should have read slower...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si »</TD></TR><TR><TD CLASS="quote">it doesn't look like the 7al-2 can be programmed to run a 4 cyl. the car runs but no rev limit or 2 step</TD></TR></TABLE>
its because you,most likely, bought an 8 cyl box, they make a specific box for a 4 cyl... i belive it has a 4 at the end of the part number.
part numbers are as follows.
121-7220---7AL-2 Ignition Control--- 8-cyl.
121-7224-- 7AL-2 Ignition Control--- 4-cyl
121-7226----7AL-2 Ignition Control---6-cyl. (even fire only)
121-7250---7ML-2 Marine Race Ignition----- | View Product
JEGS
btw. i have a 7al, 4cyl box for sale.
Modified by Dturbocivic at 10:20 AM 4/25/2005
JEGS
Integrity_On_Wheels
Oct 13, 2005 11:01 AM
