zc gears into dx transmission?
Old Apr 24, 2005 | 11:58 AM
psicrxsi's Avatar
Default zc gears into dx transmission?
i know everyone talks about hybrid trannys and swapping gears between the si and zc trannys, would the zc 1-5 gears be swappable into the dx tranny? this would basically give the dx tranny the same gear ratios as the zc tranny.
gears
ZC DX
1st 3.250 3.250
2nd 1.944 1.894
3rd 1.346 1.259
4th 1.033 0.937
5th 0.878 0.771
FD 3.888 3.888
Old Apr 24, 2005 | 12:12 PM
vegaskurt's Avatar
Default Re: zc gears into dx transmission? (psicrxsi)
You would probably want to use the DX diff and final drive so you wont have to find new axles. But putting the zc gears in will give u a nice close (usable) ratio.
Old Apr 24, 2005 | 12:22 PM
psicrxsi's Avatar
only reason i brought this topic up is because with a zc tranny install you have to have the zc intermiate shaft and 90-93 teg axles. the zc intermediate shafts are hard to find arent they...thats what i keep on hearing. so i just swap some of the zc gears into the dx tranny, the dx tranny will be just like the zc tranny.
Old Apr 26, 2005 | 12:54 PM
psicrxsi's Avatar
any more input?
Old Apr 26, 2005 | 02:40 PM
redzcstandardhatch's Avatar
something different
it should work just fine.
Old Apr 26, 2005 | 06:55 PM
jlicrx's Avatar
make sure the ZC transmission and the DX transmission have the same number of splines on the input shaft so you can use your same clutch
hondacivic90zc
12
Apr 2, 2008 07:17 AM
LigerZeroWPC
Dec 22, 2005 11:21 AM
silver hatch
13
Mar 19, 2005 08:09 PM
jadugartir
Sep 10, 2004 11:43 AM
TheBlackCrx
Apr 10, 2003 05:57 PM
