H22 Flywheel bolt Help
I am having the hardest time removing the Flywheel bolts from my 97 Prelude H22. I am using an impact gun and I was only able to remove two of them. Anyone else had this problem? Only thing left to try is a torch and/or air chisel. Any hlep would be appreciated.
They're probably Loctite'd and have been on a loong time.
Try some PB Blaster. Let it sit overnight. Then try it again; if it doesn't work, tap it a time or two in "forward" then hit it in reverse again.
Nathan007
Jun 17, 2009 08:56 PM
