H22 Intakes and Velocity Stacks
Old Apr 24, 2005 | 10:30 AM
mgags7's Avatar
Default H22 Intakes and Velocity Stacks
Im trying to get a good idea of what the best setup for an h22 intake is.
Right now i have a j's racing "whale *****" and i have been reading up a lot on velocity stacks. Im really interested in putting together some kind of velocity stack intake.
A lot of the setups i see are b series, but i figure the flow dynamics will be for the most part the same....just with more volume needed here to feed the H22. A lot of the setups are just short rams with a stack on the end. Jeff at IB said to put the stack on the end of the AEM cold air my friend has all the way down in the fender. I want to figure out whats gonna work best for me as far as:
Whether to use a short ram or the full cold air?
What piping diameter to use?
Stack size to use, im pretty sure the IB one is 3 inch where it goes into the intake
Possibly try to get one made for the J's....some guy did a custom one for his j's, but instead of going over the end, it slid in all the way, and then the regular filter fit over the end. Not sure whether it would work or not that way, considering after the air goes through the stack it is let off an edge to the bigger diameter j's pipe.....
what do you guys think?
EDIT::here are some pages on h-t about velocity stacks FYI...
https://honda-tech.com/zerothread?id=1211917
https://honda-tech.com/zerothread?id=1195140 - j's stack as noted above
Modified by mgags7 at 3:32 PM 4/24/2005
Old Apr 24, 2005 | 11:51 AM
mgags7's Avatar
bump with some more intake info....here is an AWESOME page of info
https://honda-tech.com/zerothread?id=1169765
Old Apr 24, 2005 | 03:26 PM
HooTeNannY's Avatar
Default Re: H22 Intakes and Velocity Stacks (mgags7)
I would also like to know about this. Is the "magic intake" from Import Builders just a velocity stack thing that you add on to your existing intake?
Old Apr 24, 2005 | 03:57 PM
mgags7's Avatar
bump for some info...
Innovation's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">Jeff at IB said to put the stack on the end of the AEM cold air</TD></TR></TABLE>
Thats not really a good idea. A larger velocity stack, like the one you would use on the end of an intake tube as apposed to a ITB set up requires area in which it can draw air from every direction. Its best positioned outside of the car where it is able to draw from adequite spacing (nothing in front of, behind or on the sides). A velocity stack is more or less a vacum draw, it draws air from all around the radius lip.
The actual shape of the J's intake is not really necessary with a velocity stack. Your going to want something that starts out at a 3.5 inch ID and makes its way down to about 2.75 at the intake to TB transition, a cosntant diameter will also work well... The taper is just my personal preference. The actual length and or taper degree will be dependent on your set up/rpm range.
Modified by Innovation at 5:14 PM 4/24/2005
Old Apr 24, 2005 | 04:17 PM
mgags7's Avatar
i have seen a few of the intakes that jeff sells.....they look like they do that taper buit i cant tell for sure from the pics....
how adversely is the stack's performance effected by being inside the engine bay somewhere vs being in open air.....and do you think that in the fender or in the traditional short ram spot is better for the stack?
Old Apr 24, 2005 | 04:23 PM
cpforyou's Avatar
Default Re: (mgags7)
Can it make that big of a difference?
When I went to the dyno at Church Automotive, one the the last things Shawn did was disconnect my air filter, and put his magic velocity stack on it. It made no gains or losses.
Old Apr 24, 2005 | 04:27 PM
Innovation's Avatar
Default Re: (cpforyou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpforyou &raquo;</TD></TR><TR><TD CLASS="quote">Can it make that big of a difference?
When I went to the dyno at Church Automotive, one the the last things Shawn did was disconnect my air filter, and put his magic velocity stack on it. It made no gains or losses.</TD></TR></TABLE>
The specs for the stack and tube itself play a big part in the function of the intake. Have Joe from Prototype Racing build you one specific for your set up... It will defenitely make a difference
Old Apr 24, 2005 | 04:29 PM
Innovation's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">i have seen a few of the intakes that jeff sells.....they look like they do that taper buit i cant tell for sure from the pics....
It makes a huge huge difference being outside of the car as apposed to inside the engine bay.
BTW, I have an IB intake, its a constant diameter from start to finish
Old Apr 24, 2005 | 04:44 PM
optikal_blitz's Avatar
any pics? i dont understand how the stacks are being installed..
Old Apr 24, 2005 | 04:50 PM
Innovation's Avatar
Default Re: (NatakuBlitz)
Old Apr 24, 2005 | 04:53 PM
oh aren't the folks over at iceman making a replacement headlight for air induction?
Old Apr 24, 2005 | 04:58 PM
Sam1am26's Avatar
You would see better gains from a velocity stack if it were outside the car on the street/track... Even fans don't simulate the air rushing through the engine bay at 100 mph...
Old Apr 24, 2005 | 05:01 PM
Innovation's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NatakuBlitz &raquo;</TD></TR><TR><TD CLASS="quote">oh aren't the folks over at iceman making a replacement headlight for air induction? </TD></TR></TABLE>
Yeah, but the AFS system Iceman makes doesnt come close to a velocity stack and a aplication tuned intake system... Even Andy Knight (Iceman/Knight Engineering) himself will tell you that...
Old Apr 25, 2005 | 02:50 AM
mgags7's Avatar
so is there any way to use a velocity stack on a street daily driver and get good gains?
Old Apr 25, 2005 | 04:09 AM
Innovation's Avatar
Its more or less a track only thing.. Driving with an open velocity stack everyday can, and in most cases, will cause your motor to injest some nasty **** here and there... Dirt, dust, debree, etc, etc
Old Apr 25, 2005 | 08:33 AM
98TypeSH's Avatar
Default Re: (Innovation)
Are you talking about running just a stack ? Or stuff a stack in your current intake then putting the filter back over it ?
Old Apr 25, 2005 | 08:38 AM
The Birdman's Avatar
we (me and mgags7) were both talking with jeff about this and there would definitely be a filter over the end of it....
i would never daily drive with an open intake....
cycopath
15
Jul 15, 2008 05:01 PM
mickyT
Nov 13, 2007 10:35 AM
accrdvtec
Nov 2, 2005 08:34 AM
.jacob
Dec 17, 2003 01:21 PM
TylerB
Aug 29, 2003 06:58 PM
