New motor
Old Apr 24, 2005 | 05:32 AM
saintspall's Avatar
Default New motor
Hi,just builg a new engine and was wondering what HP m i looking at?
B20 duct block with 85mm cp piston 11CR
Eagle con rod eagle 95 crank
b16 head with JUN3 cams,JUN valve spring and crower tt retainer
JUN ECU and Greddy E-manage
Edelbrock victor x intake manifold with edelbrock 65mm tb
Am sourcing around for a header was wondering if a side exit header would be good?
Old Apr 24, 2005 | 03:15 PM
murtnabila's Avatar
Default Re: New motor (saintspall)
if it's not for street get side exit
Old Apr 25, 2005 | 08:16 AM
saintspall's Avatar
Default Re: New motor (murtnabila)
Thanks,was looking at getting RMF
Old Apr 25, 2005 | 08:24 AM
97L-esVeeTeg's Avatar
if its not for the street, why not higher compression, with an 85mm bore you can go higher in compression and still keep a relatively flat piston.
Old Apr 26, 2005 | 09:14 AM
saintspall's Avatar
Default Re: New motor (97L-esVeeTeg)
Its actually my daily drive,currently the engine is in a ek4 4 dr,weight of the car is about 2200kg,right now we are encoutering some prob.I'm using a spoon ecu and its suppose to rev pass 9k but right now it is being cut at 8k.anyone know the reason?could it be the injector?
revsforglory
Jan 9, 2017 08:38 AM
andersonkid531
17
Nov 7, 2011 07:43 AM
DA93teg87
43
Apr 22, 2011 05:56 PM
insomniac791
116
Feb 28, 2010 10:18 PM
