195-55-15 and 205-50-15 set up
Old Apr 23, 2005 | 10:44 PM
jvcnyc's Avatar
Default 195-55-15 and 205-50-15 set up
I saw this set up in a car, 195-55-15 in the rear and 205-50-15 in the front. I was wondering what you guys think? I am planning to get next tires and it was the first time i saw this set up.
Old Apr 23, 2005 | 11:16 PM
dc2rboost's Avatar
Default Re: 195-55-15 and 205-50-15 set up (jvcnyc)
umm.. sounds cool.. nice fattys in the front for burn outs!! haha
Old Apr 23, 2005 | 11:20 PM
Lanceuppercut's Avatar
Default Re: 195-55-15 and 205-50-15 set up (westcoastRICE)
u need 195 55 15 and in the front 205 50 16 baby
Old Apr 23, 2005 | 11:54 PM
huntarrr's Avatar
why dont you get 205/50's all around.. makes no sense to me
Old Apr 24, 2005 | 12:02 AM
dc2rboost's Avatar
yeah what he said/\
Old Apr 24, 2005 | 01:35 AM
dantastic's Avatar
why not just get 205's all the way around so u can rotate ur tires? the 10mm difference in x-section width is barely noticeable. that person probably had that "setup" b/c he replaced the tires one pair at a time
Old Apr 24, 2005 | 01:37 AM
MulletManRockStar's Avatar
Default Re: (dantastic)
yep just like im gonna have to do. 40's and 50's in back because im to broke to buy 4 tires when I only need two. Damn I need a camber kit.
Old Apr 24, 2005 | 03:42 AM
97civicdx's Avatar
What year civic was it? If it was a 96 and up, its to prevent rub in the rear due to his wheel choice. It actually causes better traction up front.
Old Apr 24, 2005 | 06:41 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jvcnyc &raquo;</TD></TR><TR><TD CLASS="quote">I saw this set up in a car, 195-55-15 in the rear and 205-50-15 in the front. I was wondering what you guys think? I am planning to get next tires and it was the first time i saw this set up. </TD></TR></TABLE>
If you stagger your tire sizes, you won't be able to rotate them. Just keep them all the same size for a street car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MulletManRockStar &raquo;</TD></TR><TR><TD CLASS="quote">Damn I need a camber kit.</TD></TR></TABLE>
You probably just need an alignment.
Old Apr 24, 2005 | 09:41 AM
jvcnyc's Avatar
Default Re: 195-55-15 and 205-50-15 set up (Targa250R)
I saw this setup in a a video of a japanese Spoon civic,
Old Apr 24, 2005 | 10:45 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jvcnyc &raquo;</TD></TR><TR><TD CLASS="quote">I saw this setup in a a video of a japanese Spoon civic, </TD></TR></TABLE>
Most Japanese competition cars stagger their tire sizes to get rotation despite having a front-stiff spring bias. Here in the US, we don't see staggered tires as often because of the popularity of rear-stiff spring biases.
Old Apr 24, 2005 | 11:02 AM
RedDC5's Avatar
Default Re: (MulletManRockStar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MulletManRockStar &raquo;</TD></TR><TR><TD CLASS="quote">yep just like im gonna have to do. 40's and 50's in back because im to broke to buy 4 tires when I only need two. Damn I need a camber kit.</TD></TR></TABLE>
Me too, man i know how it is, i have to travel to and from Georgia and Florida.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">You probably just need an alignment.</TD></TR></TABLE>
Not necessarily true, a shop cant fix your camber if your car is too low, your wheels bow out too much, only toe and caster, thus forth the reason for aftermarket camber kits to match with springs.
Old Apr 24, 2005 | 12:14 PM
spock_rocker's Avatar
memoryFAB.com representative
shakes head.
Old Apr 24, 2005 | 03:17 PM
Dave421's Avatar
Default Re: (4door_ridin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door_ridin &raquo;</TD></TR><TR><TD CLASS="quote">
and that's why he's recommending an alignment. Camber won't cause more than 5% of tire wear unless you're running insane amounts. I run 2.5-3.5 every day with no issues. TOE wears your tires out. Get an alignment and get your toe fixed
Old Apr 24, 2005 | 03:23 PM
stormy's Avatar
Default Re: (Dave421)
shorter LCA's in the rear
The japanese do run a staggered tire size as you can usually run a wider tire in the front and to do less is giving up traction
hower it's usually like 235f 205r or 245f 215r
running 205's all around will be good for street use with a little fender rolling so you can correct camber a bit for when you're not going full speed around a corner
Old Apr 25, 2005 | 09:09 AM
555R's Avatar
Default Re: (stormy)
the reason is to allow the car to rotate in the corners more
it allows the rear of the car to come around...its also dont with tire width for the AWD mitsubishis
they run for exampl3 and 8 inch wide front with a 7.5 rear to change the alignment of the sidewalls
also to allow for rotation
its not a cosmetic reason but a suspension tuning reason
try it out sometime
if you arent into serious road racing then I wouldnt bother to run staggered
tires
my current setup is a 215-45-16 front 16x7 and 205/50 15 rear 15x6.5
RedDC5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave421 &raquo;</TD></TR><TR><TD CLASS="quote">
and that's why he's recommending an alignment. Camber won't cause more than 5% of tire wear unless you're running insane amounts. I run 2.5-3.5 every day with no issues. TOE wears your tires out. Get an alignment and get your toe fixed</TD></TR></TABLE>
Most shops wouldn't even try to give me an alignment without a camber kit, i may try this, but still i want a camber kit. guess your right, i dont know,
Old Apr 25, 2005 | 10:26 AM
Mike_C's Avatar
tuning with tires = dumb. get all the rubber that you can fit.
Old Apr 25, 2005 | 10:36 AM
555R's Avatar
Default Re: (Mike C)
you are all entitled to your opinons about that subject
nuff said
Old Apr 25, 2005 | 11:21 AM
jonshonda's Avatar
Community Builder
running bigger tires up front and smaller tires in the rear(on a fwd car) will give it more nuetral handling. But I would run 195 all the way around if you don't want to rub.
h8ted ek
Jan 14, 2009 02:10 PM
b16bri
May 19, 2008 06:04 PM
520lbGIANT
Apr 6, 2007 02:13 PM
msedacca
Jul 31, 2006 02:41 PM
Renegade
22
Oct 2, 2003 03:51 AM
