DPFI to MPFI question?
Just swapped an LS-VTEC into my EF sedan. Did the wiring conversion from DPFI to MPFI. Since the wiring conversion was from single DPFI to single MPFI, my question is, would it matter if I used a SOHC or from DOHC dizzy. As of right now I'm not getting spark. Checked the wiring conversion several times and it seems to be correct. The conversion that I did for the wiring was from Dx to SI, would I need to use an 88-91 Si dizzy.Would it even bolt up on a DOHC motor? The dizzy that i have now is an OBD0 b16 with new cap and rotor, and also using PR3 ECU but no spark. Any suggestions?
b_jonston
Apr 19, 2007 06:14 PM
