new dyno numbers-558.9
just got home from the dyno to check and make sure the tune was ok on the new build.it made 558.9whp and 369.2 torque.it spools about 600 rpm faster and makes a good bit more on the bottom end.it could be more, but i have ran out of injector and it won't make anymore boost(26 psi) with the current wastegate spring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic »</TD></TR><TR><TD CLASS="quote">what is the setup</TD></TR></TABLE>
any pic's or vid
any pic's or vid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anothaRRR »</TD></TR><TR><TD CLASS="quote">Nice
Lets see some 10's now.</TD></TR></TABLE>
yeah.on radials
Lets see some 10's now.</TD></TR></TABLE>yeah.on radials
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civicsi »</TD></TR><TR><TD CLASS="quote">
any pic's or vid</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">sleeved b18c?</TD></TR></TABLE>
sleeved b18c5
sleeved b18c5
i will give you the condensed version of the setup:
-golden eagle sleeved b18c5
-crower rods-je pistons(81mm)9.0:1
-supertech .5mm oversized flat bottom valves
-supertech valvesprings and retainers
-custom turbo kit(by me) including t-62
-720cc injectors(at 100% duty cycle)-that's the next thing on my list
-power fc
i think that would about sum up the main modseverybody asks for.
i don't have any recent videos because my camera is broke, but there are some videos on vwsport.com.go under download movies,then chose honda videos and danny's itr.
-power fc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vangc6780 »</TD></TR><TR><TD CLASS="quote">what kind of manifold is that???
is that better than equal length???</TD></TR></TABLE>
that is a custom manifold that i made.it uses a divided turbine housing and it is equal length.all runners are within .25" of one another
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR »</TD></TR><TR><TD CLASS="quote">i will give you the condensed version of the setup:
-power fc
What fuel pump? Stock fuel lines?
-power fc
