How do to repair keyholes?
Old Apr 23, 2005 | 06:12 PM
eg686's Avatar
Default How do to repair keyholes?
The keyhole is just tored apart so I need to replace it. I assume I will need to go through the door panel. Do I need to get a new door handle section?
If I replace the keyhole will I need to get new keys....im very confused right now.
Any suggestions? I dont want to shave it either.
Old Apr 23, 2005 | 07:04 PM
TallAssFilipino's Avatar
Default Re: How do to repair keyholes? (dchan86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dchan86 &raquo;</TD></TR><TR><TD CLASS="quote">The keyhole is just tored apart so I need to replace it. I assume I will need to go through the door panel. Do I need to get a new door handle section?
Any suggestions? I dont want to shave it either.</TD></TR></TABLE>
After you take the interior door panel off, there should be two bolts holding the inner side of the door lock/handle. You can either replace the entire thing or just the keylock. If you do replace with another keylock, you'll need the corresponding key(s) for it as well.
Old Apr 24, 2005 | 12:23 AM
eg686's Avatar
Default Re: How do to repair keyholes? (MDJ IKNJ)
damn sounds like alot of work, so I would need to replace the keyhole to start the car also...?
Old Apr 24, 2005 | 12:30 AM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
No, using two different keys is something done at your own discretion. If it's just that driver door, you can choose to replace just that key hole, find out if a keyhole replacement can be shaved to the spec of your current key. If not, and you want to save money, just have the driver door done and a use the same key you've always used for the ignition.
Old Apr 24, 2005 | 11:06 AM
hatchi's Avatar
you can change just keyholes and transfer over your cylinder in the new one. YOu can retain the use of your old key
Old Apr 24, 2005 | 03:41 PM
eg686's Avatar
Default Re: How do to repair keyholes? (hatchi)
cool. Ill have pics next week.
dmc12321
Nov 20, 2014 09:02 AM
slammedz6ef
Sep 22, 2010 04:42 PM
h22_crx
Oct 12, 2005 02:14 PM
CivicHP
Apr 17, 2005 04:17 PM
SPOONup
Apr 13, 2004 08:00 PM
