b16a o2 sensor wiring question?? strange!
Old Apr 23, 2005 | 06:11 PM
japrex's Avatar
Default b16a o2 sensor wiring question?? strange!
ok, i have my pr3 b16a engine swapped in my 88 crx hf. i accidently sold my stock hf wiring harness so i had to pick up an 89 hf harness which should be the same. tonight im hooking up all the wiring connections to the engine and it seems as though i only have one connector for one o2 sensor. i really didn't pay attention to see if my stock HF engine had only one o2 sensor but if it did then do i just wire the second one up directly to the ecu? i know i sound like a dumbass but it's confusing. thanks for any help.
Old Apr 23, 2005 | 08:51 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: b16a o2 sensor wiring question?? strange! (japrex)
yes your harness will only have 1 o2 sensor wire, best bet is to run both o2 sensors to their correct pinout to the ecu
Old Apr 23, 2005 | 08:58 PM
doublethink's Avatar
Default Re: b16a o2 sensor wiring question?? strange! (PURPLETERROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR &raquo;</TD></TR><TR><TD CLASS="quote">yes your harness will only have 1 o2 sensor wire, best bet is to run both o2 sensors to their correct pinout to the ecu</TD></TR></TABLE>
the d only has one o2.
^^^^ thats a good suggestion to avoid mixing them up and getting bogging under acceleration.
Old Apr 24, 2005 | 09:05 AM
mar778c's Avatar
Community Builder
Community Influencer
Just like PURPLETERROR said, or you can wire them and switch the plugs.
Old Apr 24, 2005 | 09:28 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: b16a o2 sensor wiring question?? strange! (mar778c)
Or you can switch the positions of the two sensors in
the exhaust manifold so the round sensor plugs in to its stock location
and then add the second wire to C8.
zach1288
Mar 6, 2009 04:02 AM
D21X
Apr 7, 2005 01:24 PM
plastik462003
Jan 3, 2005 02:46 PM
Undrgrndhaqer
Feb 5, 2004 05:49 PM
