B16A vs. B18C5 vtec solenoid
Old Apr 23, 2005 | 03:13 PM
Stoich's Avatar
Default b16 vs b18c5 vtesh solenoid
Does anyone know if a b16a2 and jdm b18c5 vtec sol are interchangable?
help?
Old Apr 23, 2005 | 03:32 PM
radteg's Avatar
they should all be interchangable
Old Apr 23, 2005 | 04:05 PM
98DC2-ITR's Avatar
Default Re: b16 vs b18c5 vtesh solenoid (Stoich)
Solenoid itself is the same. If you need to change the housing the USDM and JDM housings are different for the VTEC parts. JDM does not have VTEC pressure switch like USDM. You can drill and tap the JDM housing but it is kinda a pain..
Old Apr 23, 2005 | 04:22 PM
1fastvik's Avatar
Default Re: b16 vs b18c5 vtesh solenoid (98DC2-ITR)
Sorry you are wrong. Both solenoid's are the same and they are compatable
Old Apr 23, 2005 | 04:26 PM
Comp97GSR's Avatar
Default Re: b16 vs b18c5 vtesh solenoid (1fastvik)
wtf is vtesh???
Old Apr 23, 2005 | 04:27 PM
98DC2-ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98DC2-ITR &raquo;</TD></TR><TR><TD CLASS="quote">Solenoid itself is the same. If you need to change the housing the USDM and JDM housings are different for the VTEC parts. JDM does not have VTEC pressure switch like USDM. You can drill and tap the JDM housing but it is kinda a pain..</TD></TR></TABLE>
Read my full post before telling me i am wrong I said solenoid is the same just housing is different. IE plate that mounts vtec solenoid and press. switch to the head... Didn't say solenoid was different just mount...
Old Apr 23, 2005 | 04:37 PM
330R's Avatar
Default Re: b16 vs b18c5 vtesh solenoid (Comp97GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">wtf is vtesh???
I dunno, but it conjures up thoughts of John Tesh hitting VTEC
Old Apr 23, 2005 | 04:49 PM
Comp97GSR's Avatar
Default Re: b16 vs b18c5 vtesh solenoid (330R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 330R &raquo;</TD></TR><TR><TD CLASS="quote">
I dunno, but it conjures up thoughts of John Tesh hitting VTEC </TD></TR></TABLE>
That is what I thought............... boy that was scary.
Old Apr 23, 2005 | 04:51 PM
01-0720's Avatar
thank you for the mental picture of john tesh hitting vtec
Old Apr 23, 2005 | 04:56 PM
330R's Avatar
Default Re: b16 vs b18c5 vtesh solenoid (01-0720)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">thank you for the mental picture of john tesh hitting vtec </TD></TR></TABLE>
Let me add to your mental image.. Mary Hart riding shotgun, playing with the radio and talking loudly in her Cosmo Kramer-seizure-inducing voice
..in an ITR, to keep it relevant..
Old Apr 23, 2005 | 05:12 PM
01-0720's Avatar
ok i just threw up in my mouth please stop
Old Apr 24, 2005 | 05:41 AM
Stoich's Avatar
i have a 00 Jdm Itr and the vtec solenoid has one green wire coming out of it but has been cut so i want to change it for one with plugs
so i can use one from say a gsr or b16?
Old Apr 24, 2005 | 06:37 AM
jimmy tuned's Avatar
You can tell them apart by size the JDM b-16 soleniod is huge compaired to any USDM solenoids
Old Apr 24, 2005 | 07:23 AM
splitime's Avatar
They are interchangable. You also have options for the wiring. All thats needed is the vtec solenoid wired up... the pressure switch (not on jdm setup) can be ignored. You can run a jumper between the 2 vtec wires at the ecu and it'll work perfectly fine. Or you can just swap the solenoid between the 2 bases.
Old Apr 24, 2005 | 07:56 AM
Stoich's Avatar
Default Re: b16 vs b18c5 vtesh solenoid (splitime)
ok i got a b16 one cheap so i can just swap out the top(solen) on the jdm base?
Old Apr 24, 2005 | 02:18 PM
Stoich's Avatar
bump bump
I need mAd jDm type Er power on my hatchie
Old Apr 24, 2005 | 04:15 PM
Stoich's Avatar
Old Apr 24, 2005 | 04:30 PM
ZygSpeed's Avatar
Please realize that there is a no bumping policy in the ITR forum (see stickies, etc.).
Good luck with your VTEC problems. Can this be locked now?
meheartmycivic
Sep 1, 2010 11:13 PM
Holst56
Oct 21, 2008 10:32 AM
duceducecord
Jan 29, 2007 03:14 PM
baonest1
Jan 4, 2004 10:22 PM
SLOW4drINTEG
May 5, 2003 10:47 PM
