can't get the axel out
Old Apr 23, 2005 | 01:50 PM
kysmith's Avatar
Default can't get the axel out
my 97 sh won't let go of the driver's side axel that mates up to the ATTS. alldatapro says to just pry it out, but it won't come. The passenger's side axel just came out but this other one won't come. Am I missing some step in this whole process?
Also I gotta remove the ATTS next is that a bitch or does it come out easily once you got everything else removed?
Old Apr 23, 2005 | 03:29 PM
stupidfox's Avatar
Default Re: can't get the axel out (kysmith)
if it the side that goes into the tranny, you should be able to pry it out, just get a big screwdriver and give it a quick pop, if that isn't wortking, try taking a block of wood (2x4 works), put it against the shaft and tap the other end of the block with a hammer. Should do the trick for ya.
Old Apr 23, 2005 | 06:35 PM
mxer518's Avatar
Default Re: can't get the axel out (thestonerhimself)
a big tire iron will allways pop them off if you are replacing the axles dont worry about hurting it....
Old Apr 23, 2005 | 07:46 PM
DavidT or VajT's Avatar
Default Re: can't get the axel out (mxer518)
Crowbar!!!
And don't forget, leverage is your friend
Old Apr 23, 2005 | 08:19 PM
Innovation's Avatar
Ive never heard of a car with an axel
Is that anything like an axle?
Old Apr 23, 2005 | 09:25 PM
AzCivic1.6's Avatar
if its possible use two pry bars opposite of eachother.
Old Apr 24, 2005 | 04:26 PM
cpforyou's Avatar
Default Re: can't get the axel out (Innovation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Innovation &raquo;</TD></TR><TR><TD CLASS="quote">Ive never heard of a car with an axel
Is that anything like an axle? </TD></TR></TABLE>
Old Apr 25, 2005 | 10:36 AM
kysmith's Avatar
goterdone
Old Apr 25, 2005 | 01:10 PM
stupidfox's Avatar
Default Re: (kysmith)
kick ***
Old Apr 25, 2005 | 02:18 PM
Quaalude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mxer518 &raquo;</TD></TR><TR><TD CLASS="quote">a big tire iron will allways pop them off if you are replacing the axles dont worry about hurting it....</TD></TR></TABLE>
This is what I always use. Pop one side with a hammer and it'll come right out.
H23_del_soul
25
Aug 23, 2010 04:19 AM
Jose-aka-Pedro
Sep 20, 2006 07:59 PM
Agito
Sep 12, 2006 05:18 AM
7808
Aug 24, 2005 10:56 AM
rasinhell
Jan 13, 2005 09:52 PM
