Energy suspension motor mounts installation
Old Apr 23, 2005 | 12:21 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Energy suspension motor mounts installation
How exactly do you install these mounts?
I couldn't find a FAQ, all i Found was input on that they were worth the money?
DO i need a torch to burn out the olld rubber or they fit right in?
Also how much do they go for?
I don't want to get ripped
thanks
Old Apr 23, 2005 | 12:43 PM
Prod's Avatar
Default Re: Energy suspension motor mounts installation (MugenHonda)
something like 40 bucks...once you get them you'll feel silly for asking how to install. they fit right in the stock mount like a lego heh
Old Apr 23, 2005 | 01:02 PM
rmcdaniels's Avatar
You probably found some stuff about the ES suspension bushings. The motor mounts just pop in, only problem is getting at the rear mount. I did mine when I had the engine out, so it was easy, but I'm not sure how you'd access the rear mount with the engine in, maybe by removing the intake manifold.
Old Apr 23, 2005 | 01:13 PM
Heylookits shawn's Avatar
Default Re: (rmcdaniels)
its really not that hard to get the rear mount in, you just have to move the black canister thing and its just a matter of wiggling the mount out and popping it in. the problem with the two other ones is they tend to pop out after a while, happened to my friend and i just found out today mine popped out.
Old Apr 23, 2005 | 02:06 PM
turbo_b16_ex's Avatar
your gonna have to take the back one out. and as for them poping out i have a perfect soulution. trash the zip ties, and 2 hold in them. then goto hardware store, pick up some long skinny bolts, some washers and some nuts. torque em and they ready to do. mine never flex.
Old Apr 23, 2005 | 02:08 PM
im sorry. i meant drill two holes in them. or you can go get polyurathan from home depot and let it dry for a few days. that will work just as good, but u cant drive it or it will squish out.
Old Apr 23, 2005 | 02:54 PM
MugenHonda's Avatar
Default Re: (turbo_b16_ex)
Wow thanks for the fast reply, I guess will pick up a set.
thanks
Old Apr 23, 2005 | 02:58 PM
ironlung78's Avatar
Default Re: (MugenHonda)
i had to take both lower front ones off, losen the top 2, and lower the engine on the jack to get to the back one on my b16
Old Apr 23, 2005 | 04:45 PM
EG6 SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo_b16_ex &raquo;</TD></TR><TR><TD CLASS="quote">your gonna have to take the back one out. and as for them poping out i have a perfect soulution. trash the zip ties, and 2 hold in them. then goto hardware store, pick up some long skinny bolts, some washers and some nuts. torque em and they ready to do. mine never flex.</TD></TR></TABLE>
You can do that, or buy the Prothane Inserts. They are full hardened polyurethane and I have not had any issues with them popping out.
Marlon88
Jan 8, 2008 09:51 AM
CRXified
Dec 28, 2006 08:40 PM
dreams190
Feb 11, 2006 05:28 PM
Patron
Jan 18, 2003 06:28 AM
DroppedTegra
Jan 6, 2002 10:30 AM
