removing mouldings for paint, cant get one off any ideas?
Its on a 88 CRX.
The moulding is on the outside of the door, it fills the gap between the bottom of the window and the door, its long and runs across the bottom of the window/top of door.
I removed the mirror and found an screw i removed, and it slides but i still cant get it off, i cant slide it off eaither. Anyone know wha style clips it uses?
Thanks!
Thanks!
Thanks alot, ive got a spare door ill practice on, i dont want to break anything though i wasnt sure if there were hidden clips or anything.
there are clips like every so many inches. you need to shove some thing thin in between the top of door and bottom of molding to where the clips are to release them. start from one end and work you way to the other.
JDMEK206
Jun 27, 2003 02:36 AM
