B-Series Swap Questions?
Old Apr 23, 2005 | 10:13 AM
Vizzion's Avatar
Default B-Series Swap Questions about Intake Manifolds?
Will a OBD-1 conversion on a 90 CRX HF recognize a crank shaft speed sensor?
Reason is the B18b motor that I am swaping in is out of a 96 Teg.
Also I have a 88 CRX Harness is it possible to use this harness instead of the HF Harness.
Any information will be appreciated.
Modified by Vizzion at 9:16 PM 5/4/2005
Old Apr 23, 2005 | 11:00 AM
Rywire's Avatar
Default Re: B-Series Swap Questions? (Vizzion)
your obd2 engine will just have the crank sensor unplugged, the obd1 ecu dosent look for it.
Use the harness that came with the car, and modify that, dont try a 88 harness on a non 88 car, it has differences...
Ryan
Old Apr 23, 2005 | 11:06 AM
NCchris's Avatar
First rule of engine swapping is to use the harness that came in the car if at all possible. If you plan to run obd1 or obd0 you won't need the crank sensor. I have a 95 b18b in my 90 hf and it is running obd0 with the 90 distributor, ecu and injectors. The 88 and 89 (i think) electrics are slightly different than the 90-91. I know for sure that the si and hf harness are pinned differently where they plug in by the fuse box. The plugs will interchange but the wires are in different locations.
My answer (short form) in no, obd1 does not need the crank sensor.
HTH
chris
Old Apr 24, 2005 | 05:47 PM
Vizzion's Avatar
Default Re: B-Series Swap Questions? (NCchris)
Am I going the right way in using a OBD 1 Intake Manifold or can I use any Intake Manifold. I currently have all OBD Model Intake Manifolds and Dizzys. Since it's been awhile I've updated my information, on what to do what do ya'll think is the best choice to go with. By the way I have the OBD 0 to OBD 1 Jumper Harness also. Also what ECU setup would ya'll go with I have a PR4 being OBD 0 and a P75 Ecu . I pretty much have everything for the swap. Let me know what ya'll think. THanks
Modified by Vizzion at 9:13 PM 5/4/2005
Old May 1, 2005 | 06:47 PM
Vizzion's Avatar
Anyone!
Old May 4, 2005 | 06:13 PM
Vizzion's Avatar
Can anyone help me with this one?
Old May 5, 2005 | 07:21 PM
Vizzion's Avatar
Anyone!
Old May 5, 2005 | 08:09 PM
Vizzion's Avatar
Old May 8, 2005 | 01:39 PM
Vizzion's Avatar
Can anyone help.
Old May 9, 2005 | 01:41 PM
Vizzion's Avatar
Old May 9, 2005 | 06:17 PM
Vizzion's Avatar
Old May 9, 2005 | 09:04 PM
Rywire's Avatar
You can use whatever IM you would like. B18a or b18b..
THEHULKISBETTER
Jan 31, 2017 06:44 PM
JOE BD-0
Aug 17, 2009 05:23 PM
infamousALLMTR
Nov 17, 2004 07:15 PM
deftones0817
Feb 14, 2004 11:05 AM
Towsonb16a
Jun 20, 2003 03:45 PM
