idle trouble
Old Apr 23, 2005 | 06:57 AM
mr. carpenter's Avatar
Default idle trouble
here's the setup.non obd z6 with zdyne ecu, y8 manifold, z6 injectors. no codes. when the car idles it's normal. maybe a slight drop occasionally. when i get in gear the car acts like it's hitting a limiter at 5k. when i shift it'll fall flat for a sec then pick back up. i wired the resistor wires together for the z6 injectors sort of sloppy. i just twisted them together and soldered them. i've searched some but all i'm comimg up with is fitv and timing which i know are both good. any other insight appreciated.
cancel
18
Jul 26, 2017 06:36 AM
Kanaloa5305
Mar 24, 2012 07:45 PM
bklounge30
Sep 16, 2011 06:56 PM
ToTriggerHappy
Mar 15, 2010 06:55 AM
mr. carpenter
Apr 23, 2005 04:22 PM
