What would cause this? front balancer shaft oil seal popped out
Old Apr 22, 2005 | 09:42 PM
c61lude's Avatar
Default What would cause this? front balancer shaft oil seal popped out
I have a 00 turbo prelude and I was running 8psi on an sc-61. I was workin on my car one night and I accidentaly plumbed my oil catch can wrong. (2 valves in catch can, plugged both into my valve cover). Well anyways I went out and blasted up to the top of 4th gear. Drove back home and leaked oil all the way into my garage until all the oil dropped from the motor to my garage floor. The oil came from the cover so I was'nt sure. I'm still unsure if the way I plumbed my catch can is what caused this. Well i finaly got the cover off and this is what I find. Any idea's as to why this would happen? or things you guys think I should replace while Im in here? Here is my current list of parts. You guys think I should look further or anything just let me know. Thanks! Oh and here are some pictures also because pic's make everything better.
Seals for covers
H23 Manual tensioner swap
timing belt
obviously the seal that popped out.
Old Apr 22, 2005 | 11:41 PM
boostn420's Avatar
Default Re: What would cause this? front balancer shaft oil seal popped out (c61lude)
Excessive crankcase pressure can definetly cause seals to blow out. Route the catch can properly if you havent already and replace that seal dont just push it back in. While you're there check if any of the other seals are leaking for ready to fall out and replace them as necessary.
Old Apr 23, 2005 | 06:09 AM
c61lude's Avatar
Default Re: What would cause this? front balancer shaft oil seal popped out (boostn420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostn420 &raquo;</TD></TR><TR><TD CLASS="quote">Excessive crankcase pressure can definetly cause seals to blow out. Route the catch can properly if you havent already and replace that seal dont just push it back in. While you're there check if any of the other seals are leaking for ready to fall out and replace them as necessary.</TD></TR></TABLE>
Any idea's for checking the other seals? I cannot think of anything without starting the motor up.
Old Apr 23, 2005 | 12:25 PM
1.8turbolsvtec's Avatar
there is a reacal and a little bracket holds it in place go to honda and ask for it , it is less then 10 $
Old Apr 23, 2005 | 06:36 PM
Chiovnidca's Avatar
Default Re: What would cause this? front balancer shaft oil seal popped out (1.8turbolsvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8turbolsvtec &raquo;</TD></TR><TR><TD CLASS="quote">there is a reacal and a little bracket holds it in place go to honda and ask for it , it is less then 10 $</TD></TR></TABLE>
Yea, it was probably going to come out on it's own anyway.
Old Apr 24, 2005 | 09:26 AM
c61lude's Avatar
what is a reacal?
Old Apr 24, 2005 | 11:00 AM
JDM_CD7's Avatar
There was a recall about the balancer shaft seals on the Accords/Preludes. Theres a bracket that they sell for the H22 at the Honda dealership for about $2.00. Best $2.00 ever invested.
Old Apr 24, 2005 | 12:15 PM
c61lude's Avatar
Default Re: What would cause this? front balancer shaft oil seal popped out (JDM_CB7)
awsome thanks guys!
sho_shane
May 19, 2010 10:36 AM
Dustinf
Nov 16, 2006 03:04 PM
Dr. Willy
Nov 5, 2006 10:27 PM
Boostless97Lude
Jan 26, 2003 08:20 AM
Hippie
Oct 14, 2002 03:35 AM
