h22a-crx or type R-crx
Old Apr 22, 2005 | 07:06 PM
H22A_HB
Guest
Posts: n/a
Default h22a-crx or type R-crx
i just got a crx hf and i am intersted into putting a h22a or a type R i would like to know which motor would pull better in a crx h22a or type R
Old Apr 22, 2005 | 08:55 PM
b16boost's Avatar
Default Re: h22a-crx or type R-crx (H22A_HB)
R
Old Apr 22, 2005 | 10:54 PM
520_Motorsports's Avatar
Default Re: h22a-crx or type R-crx (b16boost)
go typr r to many problems with the h in the crx. you spend just as much on the fabrication getting the damn thing in as you would if you just got the type r and a hasport mmk. plus if you brake **** it is hard to get new parts to replace everything and you have the same power in the type r anyway and it involves less fab and is awesome. vtec in b series is better anyway.
Old Apr 23, 2005 | 06:54 AM
RotiEatter's Avatar
Ditto
Default Re: h22a-crx or type R-crx (fastlx-i)
Do the ITR CRX
I don't think it is really worth the effort for the H22A CRX, but if you can do your own work then I'm sure this setup would haul ***.
Old Apr 24, 2005 | 08:26 AM
H22A_HB
Guest
Posts: n/a
Default Re: h22a-crx or type R-crx (RotiEatter)
i was wondering which motor would be faster in a crx
Old Apr 24, 2005 | 09:54 AM
JDM H23A's Avatar
Looking at your screen name I would say do the H22A swap. You already have the motor...right?
Old Apr 24, 2005 | 10:12 AM
djnikko's Avatar
Default Re: h22a-crx or type R-crx (JDM H23A)
Theres no replacement for displacement hehe
its seems the k20 would look a far nicer install, I imagine once the modifications start to get away from stock they will probably be on par performance wise. But hey im just speculating, good luck
Old Apr 24, 2005 | 02:58 PM
brian g's Avatar
Having driven both, I would say for everyday street driving the H22 pulls a little harder. When you roll the throttle on at 3 or 4 k the H22 gives better acceleration. The type R need to be in the right rpm or the throttle response is a little sluggish.
brian g
Old Apr 26, 2005 | 11:54 PM
H22A_HB
Guest
Posts: n/a
Default Re: h22a-crx or type R-crx (brian g)
thanks a lot guys
Old Apr 28, 2005 | 11:47 PM
EG92's Avatar
b20/vtec will be roughly the same price as either the h22a or ITR and will likely outperform either of those swaps.
Old Apr 29, 2005 | 08:43 AM
95accordsir-t's Avatar
Default Re: h22a-crx or type R-crx (EG92)
yea!!!!!!!
b20/VTEC
i would have to say that h-series blocks are weak in comparison to b-series, k-srs in a crx will put the valve cover like 2-3 inches above the hood and if the car is lowered the oil pan clearance is CRAZY!!
i would probably go with a gsr myself it doesnt cost quite as much and the money saved can get some bolt-ons, such as a header, or mabey even internals.
good luck anywho
Old May 1, 2005 | 12:26 PM
b16bhatch's Avatar
go with the type r motor
Old May 1, 2005 | 12:49 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brian g &raquo;</TD></TR><TR><TD CLASS="quote">Having driven both, I would say for everyday street driving the H22 pulls a little harder. When you roll the throttle on at 3 or 4 k the H22 gives better acceleration. The type R need to be in the right rpm or the throttle response is a little sluggish.
brian g</TD></TR></TABLE>
I agree with Brian. Check sig
Old May 1, 2005 | 02:02 PM
Professor15's Avatar
H22+b-series tranny= best of the both world.
iamalex1212
Sep 1, 2008 09:01 PM
JDMThoughts
Dec 13, 2004 11:16 AM
SiR Inspired ED7
May 31, 2004 04:42 PM
spangler
Jun 27, 2002 11:03 AM
