89 hatch back si with a sohc v-tec ??
Old Apr 22, 2005 | 07:05 PM
flatbackcivic's Avatar
Default 89 hatch back si with a sohc v-tec ??
i have a 89 si and i bought it wit a sohc v-tec. but the vtec doesnt kick on i was told to buy a computer.but i just dont know which computer to buy.the wireharness is the stock 89 harness.and i dont know if this matters but its ether a 93 or a 96 motor i was told those two different years from the kid i bought it from.
just would like to know what computer i need to get it to work
Old Apr 22, 2005 | 07:07 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: 89 hatch back si with a sohc v-tec ?? (flatbackcivic)
ok find your block code asuming its not a mini me.
and the code of your ECU.
it will matter what year it is.
Old Apr 25, 2005 | 10:53 AM
Default Re: 89 hatch back si with a sohc v-tec ?? (Ace$nyper)
were is the block code and?
Old Apr 25, 2005 | 11:07 AM
dr_latino999's Avatar
The block stamping is on the block to the left of the header and the right of the transmission. If you see the front mount look up from there; if the block is black in that area clean it until it you have nice shiny aluminum and then you should be able to read it fine.
Old Apr 25, 2005 | 11:47 AM
TorinRage's Avatar
Default Re: 89 hatch back si with a sohc v-tec ?? (dr_latino999)
yea i bought my 89 dx hatch it was already swapped with the d15b vtec and mine doesnt work, do to the fact i am sporting a 88 pm6 i am switching to a 90 or 91 pm6 and geetting chipped to get vtec running along with the other benifits of chipping
Old Apr 25, 2005 | 03:16 PM
Default Re: 89 hatch back si with a sohc v-tec ?? (TorinRage)
i looked and it said 93 in a circel.
so can i get my computer chipped and then will the vtec work. if so how much will it be around about number and what chip would i have to ask for and is it somthing i can do or no.
Old Apr 25, 2005 | 03:47 PM
user 98292739's Avatar
your not looking at the right spot....look at your dizzy...then go down the front till you see a square patch. if your motor is so a vtec then it should either say d16z6, or d16y8. or the guy ripped you off...why do people buy cars and dont know **** about them?
Old Apr 25, 2005 | 03:53 PM
SiR Inspired ED7's Avatar
it'll look something like this but, D***
Old Apr 25, 2005 | 04:14 PM
You said you saw 9/3, which means you saw it on the head next to the exaust ports, so by logical deduction you have a D16Z6 as that was the only 1.6L SOHC VTEC motor produced at the time. To run VTEC you will need a P28 computer and run OBD-1, or a chipped PM6 (not ebay chipped, tuned CUSTOM FOR YOU CAR INFRONT OF YOU) to run VTEC, i.e. TurboEdit.
Old Apr 25, 2005 | 04:17 PM
im kind of wondering if the head is a vtec head....so i much rather him find the block code to make sure....and if you cant find that tell us where your spark plugs are front or back of teh valve cover?
Old Apr 26, 2005 | 04:45 PM
Default Re: (LoCoReX)
i look at the pic some one put up i wen and looked at my motor at the same spot and it said ZC and nuthing after that but under the ZC it had 7407261. i didnt see D or anything
Old Apr 26, 2005 | 06:38 PM
Default Re: (flatbackcivic)
Then you have a SOHC ZC, that nifty 1.5L, or the NON-VTEC version which is the same as the A6. Can you take a picture of the motor as a whole and post it up here please?
Old Apr 26, 2005 | 07:07 PM
NACvicSi's Avatar
Default Re: (dr_latino999)
Another quick question, does it say vtec on your valve cover?
Old Apr 26, 2005 | 08:26 PM
FalkenSiR's Avatar
Default Re: (NACvicSi)
YOU HAVE A 1.6l NON-VTEC ENGINE.
Old Apr 27, 2005 | 04:32 AM
Default Re: (fast88std)
There are 2 SOHC ZCs, the 1.6L that always has ZC stamped on the block and the 1.5L with VTEC that sometimes has ZC or D15B stamped on the block.
Old Apr 27, 2005 | 06:03 AM
mawkiemarc's Avatar
you might not have v-tec
Old Apr 27, 2005 | 01:25 PM
yea it looks like you got scammed...unless you have a mini me....only way to tell now or easiest is to look at your spark plugs are they coming out from the rear or the front of the valve cover?
Old Apr 27, 2005 | 02:42 PM
on the valve cover it says v-tec and the spark plugs are in the frontof the cover
and i cant take a picture no camera. i was told it was taken out of a 2door 5 speed civic but i dont know what year. ill try to get a picture some how
Old Apr 27, 2005 | 02:49 PM
then it sounds like you have a mini me
Old Apr 27, 2005 | 03:09 PM
crxsi8's Avatar
its a ZC block with a D16z6 head because the D16y8 Head does not say Vtec on it..correct me if im wrong
Old Apr 27, 2005 | 03:32 PM
b18cEF9's Avatar
the 2 ZC single cam motors are 1.6L, one vtec, one not. the D15B vtec is a whole different animal
Old Apr 27, 2005 | 03:36 PM
Default Re: (crxsi8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsi8 &raquo;</TD></TR><TR><TD CLASS="quote">its a ZC block with a D16z6 head because the D16y8 Head does not say Vtec on it..correct me if im wrong</TD></TR></TABLE>
your wrong....92-93 does not say vtec on valve cover. 94-95 did for the z6
for the y8 i think all of them say vtec on the valve cover
Old Apr 27, 2005 | 03:54 PM
doublethink's Avatar
DOES IT HAVE A VTEC SOLENOID ON THE HEAD???
SEE HERE:
if it DOES then you need a P28 ecu and OBD1 conversion.
if it DOESNT then the current computer is fine bc he put a valve cover that says vtec on a ******* sohc zc.
the end.
Old Apr 27, 2005 | 04:33 PM
ummm a vtec valve cover will not fit on a non vtec head.....because non vtec SOHC plugs come out the rear while SOHC vtec comes out the front...that solenoid he has in the picture is for a B motor....the one on the SOHC vtec motor the green plug you see in the pic exits out the side.
Old Apr 27, 2005 | 04:37 PM
ya i have that coming out the side
