Euro R intake Manifold from se93
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LINK76 »</TD></TR><TR><TD CLASS="quote">do anybody know if se93 still sell these Manifold with the install kit?
how much was it if you've purchased it?</TD></TR></TABLE>
dude its not rocket science, just buy the manifold from any jdm part distributor , and do the work your self.
you can tap and plug any holes that you don't want, you can use a dremel to clean up the injector bosses. use and egr block of plate, very simple to make , and use a 98+ f23a1 accord IAC and you don't have to make an iac adapter plate
what come in this "intall kit" anyway? honestly guys its really not all that hard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude »</TD></TR><TR><TD CLASS="quote">
what come in this "intall kit" anyway? honestly guys its really not all that hard.</TD></TR></TABLE>
I was actually looking for the manifold, and the kit came with it. But yes, not much came with it.
which egr valve or where can I get an egr valve that fit this manifold. So I don't have to continuously rest ecu from the no egr CEL; Since atts doesn't function with the CEL on?
This after I get the Manifold of course.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LINK76 »</TD></TR><TR><TD CLASS="quote">which egr valve or where can I get an egr valve that fit this manifold. So I don't have to continuously rest ecu from the no egr CEL; Since atts doesn't function with the CEL on?
all you do is put a block off plate in between the egr valve and manifold and leave all the egr stuff pluged in as normal and it won't throw any codes because the computer thinks the egr is still fuctioning properly
