?? Installing aftermarket horn?
Old Apr 22, 2005 | 03:26 PM
turbotime's Avatar
Default ?? Installing aftermarket horn?
Hey I have an aftermarket horn im trying to hook up to my QR steering wheel. My question is, since i removed the SRS how to i hook up the horn to the wheel?
Can I just like connect a wire to the battery-to the horn switch and back to the horn? The only problem is the horn button on the wheel has only 1 positive connector, the other is ground... so I don't understand how the "switch" works...
please help! I have no horn and live in NY
Old Apr 22, 2005 | 03:53 PM
suspendedHatch's Avatar
Default Re: ?? Installing aftermarket horn? (turbotime)
Do a search in the archives. You have to get a "shoe horn" from a 4th generation Civic steering wheel. Try including "momo" or "grant" in your search. You run power to one side of your horn button, and the other side grounds when pressed in. One of the two pins in your yellow SRS harness is for the horn. Try grounding them to see which one it is.
You can't run a wire.
Old Apr 22, 2005 | 04:35 PM
turbotime's Avatar
i have a momo hub so i cant keep the srs wheel that has the horn button....
vroomeo
Feb 20, 2010 08:12 PM
zman
Oct 29, 2008 09:06 AM
saikouEF8
Jun 13, 2006 05:03 PM
714eg
Jul 20, 2003 08:36 PM
743power
Mar 31, 2003 06:48 AM
