what could it be take a look and see
Old Apr 22, 2005 | 02:10 PM
civiclxb16a's Avatar
Default what could it be take a look and see
ok i am having one last problem and it is getting on my last nerve. ok finally got my civic running and now it is not holding the charge to my battery, i took the battery to sears and they checked it out and they said it is ok to use, took the alt to the local shop and they put it on there machine and it was reading 13.9 is that normal? and is that good enough to run the car because when i put the volt meter on the battery it was saying 12.65 when it should be at 14 right? could it be my wiring harness is just shot(at the shop they chopped it up pretty badly) should i get a new harness and call it aday? let me know i want to be driving my civic no later then may 15th please help me out!!
Old Apr 22, 2005 | 02:12 PM
Cuong-nutz's Avatar
Default Re: what could it be take a look and see (civiclxb16)
Damn boy. If your alternator and battery are good looks like your wires are fucked. Replaced them and start from there.
Old Apr 22, 2005 | 02:18 PM
Tiferet's Avatar
You could always run a larger wire from the alternator to the fusebox, and bypass the whole wiring harness.
Old Apr 22, 2005 | 03:13 PM
turbo_b16_ex's Avatar
check the fuse box. i had same problem once.
lucky's Avatar
check all your grounds...especially the one coming off the battery to the frame, make sure it is clean and tight.
Old Apr 22, 2005 | 05:14 PM
Default Re: (Drip Pan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drip Pan &raquo;</TD></TR><TR><TD CLASS="quote">You could always run a larger wire from the alternator to the fusebox, and bypass the whole wiring harness.</TD></TR></TABLE>
your talking about the wire that goes on the top of the alt right? run a wire right from the that post right to the fuse box right??
Atomic1
Jun 18, 2014 02:45 PM
91grape
11
Dec 16, 2012 12:25 PM
jdm 1080p
Mar 28, 2012 02:11 PM
turbob18si
Audio / Security / Video
Dec 21, 2007 12:23 PM
civiclxb16a
Apr 26, 2005 04:54 PM
