pg7
Old Apr 22, 2005 | 01:59 PM
89 pos's Avatar
Default pg7
how can i tell what year my pg7 is
Old Apr 22, 2005 | 02:07 PM
CRXVTEC69's Avatar
Default Re: pg7 (89 pos)
you cant
Old Apr 22, 2005 | 02:24 PM
Tyson's Avatar
PG7, manual, 88-89, electronic advance.
Old Apr 22, 2005 | 02:47 PM
89 pos's Avatar
Default Re: pg7 (Tyson)
i got this off a guy with a 87 crx si when he put this on there it would not rev past 3000 so will this rule out vac advance
Old Apr 22, 2005 | 04:14 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 pos &raquo;</TD></TR><TR><TD CLASS="quote">i got this off a guy with a 87 crx si when he put this on there it would not rev past 3000 so will this rule out vac advance</TD></TR></TABLE>
That happens when you get a code regarding the distributor, thats what happened to my car, the ECU went into limp mode (rev limit ~3300 rpm) because of a loose connection at the ecu. Just becuase his revved to 3000 doesn't mean yours will not. I would try putting it onto your car, I am sure it will rev to its 7200 rpm redline The only way I see that the ecu doesn't work is if the LED on the ecu is continuously on.
As far as year on a pg7, I have no clue.
Old Apr 22, 2005 | 08:15 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 pos &raquo;</TD></TR><TR><TD CLASS="quote">how can i tell what year my pg7 is</TD></TR></TABLE>
by looking at the case:
this is 86-87 PG7
this is 88-89 PG7
KDvtec5757
Jul 1, 2008 07:30 AM
xotic_crx
Dec 11, 2006 07:44 PM
CivicRaping
Jan 31, 2005 04:36 PM
BOSS-REX
Nov 18, 2004 05:29 AM
blackrex91
Apr 19, 2003 04:33 PM
