87 Accord Carb Stalling
Old Apr 22, 2005 | 11:47 AM
Lambera's Avatar
Default 87 Accord Carb Stalling
So I originally posted this here
The car was working fine. I took the car to a friends house and parked for a few house while we went out. Came back and drove it home. It was about a 30 min trip. This problem started about 10mins from my house. The car started to stall between 2000-3000 RPMS. If I feather it and keep it at 2000 it will die. It also dies when idle at a stop. It also does this in neutral.
This is everything I have replaced.
Radiator & Thermo
VCG
Both fuel filters
New Disty, Cap, Rotor, Plugs, & Wires
New Coil
New Alternator
New Battery
New Grounds
I added a fuel gauge inline and the fuel pressure is solid, I thought maybe fuel pump. Now I’m thinking it might be a timing issue or the carb going out. I’m running out of money and I need to drive. So any dead on ideas would be great.
Old Apr 22, 2005 | 01:35 PM
Vanilla Sky's Avatar
carb is shot.. i had the same problem with mine, and i converted to EFI
Old Apr 23, 2005 | 10:26 AM
Lambera's Avatar
Default Re: (Vanilla Sky)
Thanks guess Ill go over to 3geez and take a look around. Still cant post there. I might just do a weber conversion.
Old Apr 23, 2005 | 11:26 AM
Schmitey's Avatar
Default Re: (Lambera)
carbs don't just die, and are very cheap to overhaul with a little know how
you probably got a bad float or something is clogged up
Old Apr 23, 2005 | 06:21 PM
Chiovnidca's Avatar
Default Re: 87 Accord Carb Stalling (Lambera)
Pull off your rear fuel filter and see if there is any water in it.
Old Apr 23, 2005 | 08:34 PM
DragonTLS's Avatar
try replacing the PCV valve
Old Apr 23, 2005 | 08:47 PM
carbs do get full of crap... i don't personally recommend rebuilding one if you plan on upgrading anytime soon, but these are pretty simple carbs... with a repair manual and a few hours, you can be back on the road... i just chose to go the way of EFI for reliability and fuel economy since this will be a daily driver...
just don't expect too much in the way of real performance out of these carbs...
Old Apr 23, 2005 | 11:22 PM
deserthonda's Avatar
sounds like carb problem to me as well here is what you do. remove air cleaner, on back of carb there is the idle solenoid, remove 8mm screw, take out idle solenoid, if you have access to an air gun blow pressurized air into the hole in the carb, reconnect solenoid start car make sure to plug vacc hoses so you dont have a vacc leak if it idles you got internal carb problems
Old Apr 25, 2005 | 09:20 AM
Lambera's Avatar
Default Re: 87 Accord Carb Stalling (Chiovnidca)
Just replaced the rear fuel filter after this started. I dont have the time or money to change to EFI right now. This is my DD and thats what I need asap. I guess Ill try the air thing?
blackedEk
May 11, 2011 09:29 PM
myRice
Nov 20, 2005 11:45 AM
92integraVTECgsr
Aug 30, 2005 10:39 AM
HaLfAPuNk
Jan 12, 2005 05:02 PM
chiefvtec
Mar 3, 2003 04:23 AM
