how to get head rotor off distributor?
Old Apr 22, 2005 | 11:06 AM
02z2899ex's Avatar
Default how to get head rotor off distributor?
trying to do a tune up but dont know how to get the head rotor off the distributor.
Old Apr 22, 2005 | 11:08 AM
CRXified's Avatar
Default Re: how to get head rotor off distributor? (02z2899ex)
do u mean the cap or teh rotor button? if the cap its 2 screws/bolts. if its the button u may have o roll the car over till u can see but there is a place to remove it with an allan key i belive
02z2899ex's Avatar
Default Re: how to get head rotor off distributor? (CRXified)
what do you mean roll the car over?
Old Apr 22, 2005 | 11:20 AM
Cuong-nutz's Avatar
The cap is held onto the distributor via 3 8mm bolts with philips head. You can opt to remove the distributor cap with a 8mm socket and extention or use a philips screwdriver. Once you remove th cap, you'll have acess to the distributor rotor. The rotor is hold on by a philips screw.
Old Apr 22, 2005 | 11:31 AM
silentblackhat's Avatar
Default Re: how to get head rotor off distributor? (Cuong-nutz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cuong-nutz &raquo;</TD></TR><TR><TD CLASS="quote">The rotor is hold on by a philips screw. </TD></TR></TABLE>
yep, u will hae to turn the engine over tho to get the screw to face the right direction. the screw is on the exact opposite side of the metal head on the rotor. i just turned my car over at intervals to get it to the point of the screw bein in the right place.
Old Apr 22, 2005 | 11:34 AM
IHateJDM's Avatar
Default Re: how to get head rotor off distributor? (silentblackhat)
be very careful not to strip the rotor screw! that screw is really soft, and you will have problems if you strip it.
Old Apr 22, 2005 | 11:35 AM
CRXified's Avatar
to turn car over, flick the key for a second without the dizzy cap on and it shoudl do it, have somebody watch for the button
Old Apr 22, 2005 | 11:36 AM
Cuong-nutz's Avatar
Can't believe I missed that part! Other method is to get a breaker bar and a 17mm socket and turn the crank over till you can acess the screw on the rotor
junktronic's Avatar
Even easier if you have the room is to put it in 4th or 5th with the car off and roll the car untill the screw is accesable.
Old Apr 22, 2005 | 11:42 AM
Default Re: how to get head rotor off distributor? (junktronic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junktronic &raquo;</TD></TR><TR><TD CLASS="quote">Even easier if you have the room is to put it in 4th or 5th with the car off and roll the car untill the screw is accesable.</TD></TR></TABLE>
IMO, i think its the easiest just to flick the key to the start position in quick intervals till the rotor screw comes into sight...but thats only in my opinion
Old Apr 22, 2005 | 11:48 AM
junktronic's Avatar
Well, if you dont have a helper with you or the space to do it you dont have a choice anyway. I just found it much more precise to do it the way i described above. Note this was on an EF Civic but it looks like the distributers are basically in the same position. I tried the the turn-over method and had issues getting my screwdriver in there....but i didn't unplug the electronics inside either. That could have been the problem.
Old Apr 22, 2005 | 12:09 PM
02z2899ex's Avatar
thanks guys
zairas
Oct 25, 2009 10:37 PM
polyhonda
Sep 5, 2008 01:50 PM
matmcg
Feb 15, 2008 11:04 AM
218luder
Feb 7, 2008 08:39 PM
blackls
Jul 5, 2001 07:31 PM
