Crank pully bolt
Old Apr 22, 2005 | 11:02 AM
CRXified's Avatar
Default Crank pully bolt
im worried about breaking mine off cause its being a bitch to break loose. it probably was never off before (just got JDM b16 Sir 2 swap) and i heard heating it can cause **** to go wrong and damage the bearings and warp the crank pully. is this true?
Old Apr 22, 2005 | 11:28 AM
mrDFWmechanic's Avatar
just put an allen wrench between the flywheel and block and get a long *** breaker bar and just have someone hold the motor while somebody else stands on the breaker bar. thats how i got mine loose.
Old Apr 22, 2005 | 12:45 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (iROCKtheSOHC)
Or air tools.. ive gotten mine off a few times this way.
Old Apr 22, 2005 | 02:36 PM
msmotorsports's Avatar
Default Re: Crank pully bolt (CRXified)
If this has never been taken off before you won't get it off with an air hammer. You will need the tool specialy made for this job. It is a hex head that is hollow in the center with a long breaker bar attatched to it so you can get a socket on the bolt. Moroso and Snap on makes them. I'm sure other companies do as well but can't think of any right now.
Old Apr 26, 2005 | 06:48 AM
CRXified's Avatar
Default Re: Crank pully bolt (msmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">If this has never been taken off before you won't get it off with an air hammer. You will need the tool specialy made for this job. It is a hex head that is hollow in the center with a long breaker bar attatched to it so you can get a socket on the bolt. Moroso and Snap on makes them. I'm sure other companies do as well but can't think of any right now.</TD></TR></TABLE>
borrowed 1 from the local honda dealership, came off in 2 mins with it lol
thanks
Old Apr 26, 2005 | 07:11 AM
Audi RS4's Avatar
Lover
i had to break down and buy the $200 impact wrench from sears to get mine off. The two parts that make me swear the most the carnk pulley bolt and the bitch pin in the shift linkage at the tranny.....
Old Apr 26, 2005 | 09:11 AM
Crazydave's Avatar
Default Re: Crank pully bolt (Carparts-Auction.com)
I've never had a problem removing a crank pully bolt with and air gun.
you just have to make sure that you have enough PSI
DirtyDA9
May 28, 2010 03:24 AM
Powelly
11
Sep 16, 2007 02:53 PM
BoostedH23Accord
Jul 13, 2004 05:50 PM
TRH
Sep 30, 2003 04:50 PM
