205/50 15 vs. 195/50 15 on 15x6.5 wheels
Old Apr 22, 2005 | 07:40 AM
jdmgoldcivic's Avatar
Default 205/50 15 vs. 195/50 15 on 15x6.5 wheels
I just bought a set of slipstreams in 15x6.5 and I saw a website offered 195/50 15 for 6.5 inch wheels
My question is what is the advantages and disadvantages of running 195/50 15 or 205/50 15 on these wheels?
Mainly is traction that much different with these 2 different sizes
Thanks any info will work
Old Apr 22, 2005 | 08:41 AM
Default Re: 205/50 15 vs. 195/50 15 on 15x6.5 wheels (jdmgoldcivic)
come on someone help me out I did a search
Old Apr 22, 2005 | 04:54 PM
Daniel san's Avatar
you seached huh ?
here ya go
https://honda-tech.com/zerothread?id=1209331
Old Apr 22, 2005 | 05:20 PM
Default Re: 205/50 15 vs. 195/50 15 on 15x6.5 wheels (Daniel san)
when i searched it kept on giving me a error message
thanks for the link
Old Apr 22, 2005 | 07:21 PM
GetawayInMoscow's Avatar
205/50 should only be used on 7" wheels.
Old Apr 22, 2005 | 08:19 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 205/50 15 vs. 195/50 15 on 15x6.5 wheels (GetawayInMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">205/50 should only be used on 7" wheels.</TD></TR></TABLE>
Nonsense. You can look up the approved rim widths for any 205/50-15 tire you're considering. Most are approved for rim widths of 6.0-7.0 inches. Many ITR owners mount this size on the stock 15x6 wheels with no problems (including me, for my track tires).
Your car originally came with 185/60-14 tires. I would look for tires with the same outer diameter, so that you can maintain the accuracy of your speedometer and odometer, and avoid rubbing on the fender well liners. That would be the 195/50-15. The 195/50-15 is also less expensive than the 205/50-15 (sometimes by a considerable margin).
Old Apr 22, 2005 | 08:39 PM
Default Re: 205/50 15 vs. 195/50 15 on 15x6.5 wheels (nsxtasy)
I don't really care about the speedo difference it hasn't worked since I did the LS swap.
I decided to try the Hankook RS-2 in 195/50-15 because there cheaper than the 205's and if I still have traction problems I can later on go to a 205
decko
Aug 19, 2011 02:07 AM
jdmsupreme2132
Mid-Atlantic (Sales)
Sep 7, 2010 02:55 AM
jdmfrontgsr
Wheels
Apr 13, 2010 01:09 PM
808State
Oct 19, 2003 04:42 PM
Lookincrazy
19
Apr 13, 2002 07:31 PM
